Question about ASUS P5RD1-VM Motherboard
I have the same problem
When I start my pc, no image is displayed on the monitor; not even the motherboard screen. I checked my ram, hard disk, mouse, keyboard as well. All r working properly except the motherboard. I have an ASUS P5RD1-VM motherboard, intel pentium 4 processor, 512 DDR RAM, SAMSUNG 80 GB Harddisk.
Please suggest me a solution.
  • 746 Answers
Dear! If monitor showes power but not showes display its means that monitor requires heat and it very better if you can give sun-rays. I assure your monitor will work if you do that for 4 hours. Check your monitor sepreatly with another system or computer if it works that means your VGA card not supported so you should change your VGA card but first check your monitor.
Thank You
Posted on Jul 30, 2009
When i switch my pc on i have no display?
your graphicscard not working properly, broken.
monitor cable is fitted in the graphics port?
Mar 23, 2012 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
I have an Intel D845EPI/D845GVSR Motherboard with 512MB PC266 Hynix DDR1 RAM. When i switch on my PC, the system starts but, fails to display even the first screen that it is supposed to display...
Couple of items to try. First disconnect everything except the power and the CPU. Does it give you a beep code?
If not your either have a bad power supply, motherboard, or cpu. (Only if everything else is disconnected.)
Second, If you did get the beep code then put the memory in and see if the system starts to boot. (Try without the screen connected first. If it acts like is going to start turn it off, plug in the mouse, keyboard, and monitor and try again.) ** I have seen where an add on video card would keep the computer from starting so try with the on board video first.**
Third, start adding one extra piece at a time starting with the hard drive.
Let me know if this helps or not.
Apr 22, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
All the lights come on when I switch on my HP Pavillion dv9600 but the screen is blank.
DO THIS FIRST - Perform a hard reset If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset If no error message is displayed:
If a text error message is displayed, see Troubleshooting Error Messages on a Black Screen During Startup or Boot c02076104.jpg
Black Screen with No Error Messages Connect an external monitor c02076105.gif If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance. Disconnect all peripherals and repeat the hard reset Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset , some devices are often overlooked. c02069237.gif Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.B
b52compters@gmail.com
B52computers
Chris Thrash
Jan 10, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Parts of computers and its function
Computer: A machine that processes information and performs computations.
Tower or CPU: The "box" or case that holds the parts that make up a computer: CPU, hard disk drive, floppy drive, memory chips, power supply, interface cards, etc.
CPU: Central Processing Unit, or "brains" of the Computer.
Monitor: An output display device (looks similar to a TV) in a computer system. You see information on the monitor's screen.
Screen: The viewing area on a monitor or the information or image displayed.
Disk Drive: A device that reads data from (input) or records data onto a disk for storage (output).
Hard Drive: The main device that a computer uses to store information. Most computers come with a hard drive, called drive C, located inside the computer case.
CD-ROM: ROM means Read-Only-Memory - you can only "read" information, not save. A CD can store a large amount of data including documents, photographs, software, and music (about 20 songs)
Mouse: A hand-held input device you roll on your desk to point to and select items on your screen. When you move the mouse, the mouse pointer on the screen moves in the same direction.
Speakers: Output device that produces sound and music when connected to the computer. Speakers come in different shapes and may even be in the monitor's case.
Headphones: Output device for listening that is held over the ears by a band worn on the head.
Microphone: Input device in which sound energy is changed into electrical energy for the sending or recording sound (your voice).
Scanner: Input device that reads copy as an image and digitally records the image.
Jul 05, 2010 | Dell Inspiron 530 Desktop Computer
I have my asus p5vd2 vm se mother board when i power on it wont boot
Issue : Computer is not booting
Solution --
There could be many more resons of your problem
1) there might be no display
2) there might be posible Motherbord not getting power
Please check it - in a sequence
1) remove the RAM from the Motherboard -
2) remove the Hard Disk connection to the board
3) keep the VGA Cable connected (i.e Monitor Cable)
4) Keep Keyboad and Mouse connected
5) Turn On the CPU (Cabinet) by powering it
-- Check is there any disply on the screen ?
-- Checked is there any beep sound comming ?
If both are not there - ITS a SMPS Issue
if beep is there - and No Display - its VGA Connection issue
if beep is ther display is also there - turn off the CPU connect the RAM ad turn on - if display not comming after RAM Connection then the RAM is The issue
Then Check the HDD Connection -
I know it will be resolved
dont worry do it slow and check each bit and then apply
Jan 03, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Aspire Notebook 5735-4774 won't display on external CRT monitor
If the video chip on the Aspire motherboard is OK then the image on the external monitor would be OK. If not then the video/motherboard is faulty.
To gain access to data on the hard disk, remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. The computer will see this as an external hard drive.
Alternately -
You can put the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Dec 21, 2009 | Acer Aspire 5735 Notebook
Toshiba Satellite a-100 can`t power up
The RAM could be faulty.
Try and get the RAM tested in another laptop or at your friendly computer store.
Also can you hear the hard disk spinning.
Maybe it is booting up but you can't see anything on the screen, there might be a slight image on the screen, look at it at an acute angle.
Connect an external monitor to the laptop, power up the monitor and then the laptop, if you see a normal image the the problem is the backlight on the LCD screen.
Get back to me if this is the case.
Apr 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Keyboard and mouse problem
1. You can disconnect the Hard disk then test the system if keybaord and mouse working, then there i s problem with your operating system or RAM.
2. Processor fan will rotate even after system hang up.
3. Check the RAM for cause
4. Operating may need to reinstall
May 25, 2008 | Intel D101GGC Motherboard
ASUS P5RD1-VM Motherboard Logo
138 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
