A/c doesn't get cold anymore
What does it mean when the a/c loses the ability to get cold? i have a split unit (one in living room, one in bedroom) they are fujitsu. the bedroom one no longer gets cold. it's like a fan is blowing air.
  • 26 Answers
Usually means your as unit has lost its charge and can not effectivly cool your home anymore..advise to call a certified ac tech.to find , repair and charge your units.( but in some cases a "starter relay that sits on top of the ac compressor has gone bad..this holds true to fridges also
Posted on Jul 30, 2009
I live in southeast Iowa where would the cold air returns be placed in new construction for a gas forced air system.
as cold air falls to the lowest point. placing them high would allow the cold air to flow down over the occupants
as hot air rises placing them low would allow the hot air to rise past the occupants
consult with an architect as to the best positions to place air vents.
talk with the manufacturers of the gas forced system as they will suggest the best place for their units
Dec 18, 2016 | Miscellaneous
Bedroom remote doesn't work
weak batterys wont hold codes on it huh?
Sep 24, 2012 | DISH Network Televison & Video
I have a Goodman CKL24-1k air conditioner. I live in a townhouse in Louisiana on the 2nd and 3rd floors. I set the temperature to about 73 degrees during the day so I can sleep bc I work the graveyard...
I lost you at my the end but the 2 ton unit should be able to cool 960 sqft. Sounds like a refrigerant problem. Air conditioners should cool the air 15 to 20 degrees. This means 80 degrees going into the machine in the return should be 60 to 65 degrees coming out in the supply. If you are in that range than it's likely never going to cool the space.
Jul 07, 2017 | Goodman Heating & Cooling
Hi there. When I use the source button, the s-video option doesn't appear anymore. But, the cable in my bedroom is working. Meaning, my cable is working. The tv is saying weak or no signal. It was...
Hi there
Are you watching it through a cable box in both rooms? If so, it may be that the box in your living room has packed up.
Hope this helps
TV_Doctor
Jan 03, 2011 | Televison & Video
Hi I have a starway split system air conditioner and the remote is no longer working - I have purchased an Ultra Univrsal Remote and need to know the code to make it compatible with the starway air...
In my experience, the related remote is better than universal remote, as it's not designed for particular unit, but for multi.
Anyhow, take universal remote, power on your a/c.In front of your a/c, press setting and then < or > continuously. In your remote the number will go up or down as 999.........998.997......... or 1101...102........103...104. like that. Stop, when you get response by beep sounds.That is code for your a/c to operate. Helpful?
Dec 30, 2010 | Heating & Cooling
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
The best thing for you to do is to call Mitsubishi Tech. Support directly..they are first class and will probably know exactly what the issue is...
For technical application questions, please call:
Mr. Slim: 1-800-433-4822 (press option #3).
heatman101
Aug 26, 2010 | Mitsubishi Heating & Cooling
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
I HAVE DISH NETWORK HOOKED UP IN LIVING ROOM, I WOULD LIKE TO ADD IT IN BEDROOM OFF OF THE SAME RECIEVER. I USED A SPLITTER, THE PICTURE IN LIVING ROOM IS CLEAR, BUT REALLY FUZZY IN BEDROOM. I KNOW THEY...
You will need to split the signal with a 900mgz splitter between the living room and other room. if your pic is fuzzy you have a bad splitter or bad cable, try replacing these one at a time and it should clear up. If your getting a sat pic but ti is fuzzy its for sure in the line somewhere fro teh splitter.
Nov 16, 2009 | DISH Network ViP 612
Mini Split Condensation Problems!
Maybe you need to invest in a good De-Humidifier.
Jul 08, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Maytag M6Q10F2A window A/C unit about 4 years old
buy a new effecient A/C
I had the same problem but it was my bedroom one so I swapped out my living room A/C into my bedroom and put the new one in the living room.
Jul 17, 2008 | Maytag M7Q08F2ACOM Air Conditioner
Heating & Cooling Logo
217 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
