You may have the tools, but you should pay particular attention to the warnings about the air bag. That module contains a very powerful explosive that can activate even with all power removed, and can present a very serious hazard during removal to get at the turn signal assembly. I strongly recommend either letting a pro do it, or at least get the GM service manual for the vehicle and follow the instructions very carefully.
SOURCE: 1983 cadillac fleetwood brougham 4.1 liter battery not charging
check the alternator fuse that can be a fuse link by the battery pole,check alternator voltage on the alternator red wire or connector,it should the same as on the battery ,check ground wires for loose intermitent contact
SOURCE: how to install a ignition on a 1983 cadillac
You will need a small bolt to keep the telescopic shaft held in. Has to make mine and cut the head off with a grinder.
SOURCE: 1983 Cadillac Fleetwood Brougham d'Elegance....directionals
You have a bad flasher. the 4 ways have a flasher of its own. it should be located, under dash around steering wheel. if you can not find it. call or stop into an auto parts store, and they should be able to help you auto-zone etc.
