Question about Nokia N72 Cellular Phone
My navigation keys do not working properly
My navigation & selaction keys do not working properly, some time these are not working some time these woking very fast exp:- when i am press the button one time the keys working to time.
You change your cellphone casing
Posted on Jan 07, 2013
    Problem Solver:
  • 7 Answers
It might be your navigation key has a loose connection to your cellphone that is why sometimes it does not work properly... I am recommending you that you must change your cellphone casing
Posted on Jul 30, 2009
My galaxy y has been unlock too many attemps...how to unlock my galaxy y...
first swich off your phone and prees 3 button volume up power button and home button same time than you go to recovery mode toch not working in recovery mode than prees volume down and selact wipe factory reset and prees home button and selact yes all than rebot now enjoy.... you phone will be unlock
Aug 15, 2013 | Samsung Galaxy Y GT-S5360 Factory Unlocked...
'03 Navigator will not start.
Sound Like Transmission Position Sensor ... a sensor determines when you are in Park when stopped...if not, wont start...
Other solution could be Fuse Relay...do you hear buzzing sound coming from fuse box. If so, feel which one is failing and replace. $6 at Autozone....
Mar 16, 2013 | 2003 Lincoln Navigator
Samsung c3050 phone white screen
Different Samsung phones has different methods to reset to factory default settings, today I will give you the tricks about how to reset Samsung C3050. If there is something wrong with your Samsung C3050 and make your handset slowly, the best method is to reset it.<
p>
While restore your device to factory default settings will delete all the data you saved before, and then your cellphone will be quicker than before. So you should transfer the useful information to the memory card or computer, then when you finish resetting Samsung C3050, you can transfer them back. So back up first.
-Press the Navigation key to access the main menu.
-Scroll to Settings and press the Navigation key.
-Scroll to Reset settings and press the Navigation key.
-The first time you use the phone lock code, key in a code of your own choice.
-Tick the required settings by pressing the Navigation key.
-When the box next to a menu item is ticked (V), the setting will be reset.
-Press Reset.
-Press the Navigation key to confirm.
-Key in the phone lock code and press the Navigation key.
Note: if it is the first time you use the phone lock code, key in the phone lock code again and press the Navigation key.
-The selected settings are reset.
-Press Disconnect to return to stand-by mode.
Please take note: if reset is not the best solution, I would strongly suggest to contact your manufacturer.
May 13, 2011 | Cell Phones
Hello sir my name is makarand kelkar i'm 4m mumbai my cell phone is nokia 5130 my cells kye pad is not work properly means navigation key of left & right & also go to key and music kye...
The Navigation key set can be changed, it will cost around Rs.250.... Just take it to a mobile repair shop and ask them to change the key navigation board. It is very simple, even you can buy the spare and change it yourself... But the music keys I'm Not sure they will work or not, because it is a well known complaint in Music series of Nokia and nothing can be done properly(so don waste time in spending money for music keys)...
How do we change the date on the fax machine? Someone has walked off with our manual
Hi there!
You can follow these steps to set the date:
1. Press the right navigation key and press 7.
You should see "SET MODE 1-8" "ENTER NO. OR "V ^"
2. Press 1 for
You should see "1. User Parameters?" "PRESS SET TO SELECT"
3. Press Copy/Set Key
You should see "DATE & TIME" DD-MM-YYYY HH:MM
4. Enter the new Date & Time. You can use the dial pad to enter the values & move the cursor using the navigation keys. If you make a mistake, use to move the cursor over the incorrect number, then overwrite it with a correct one.
5. Press copy/set Key then press the STOP Key
Hope this helps! Please rate if it worked.
Thanks
You can also download the manual here: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Hope this helps
Mar 30, 2011 | Panasonic UF-590 Plain Paper Laser Fax
How to you program the remote fob on a 1998 lincoln navigator
Put the key into the ignition, turn to accessories & back ( about 7 times) until the locks go up and down on their own,
then press the buttons on both of the key fobs.
Then remove the key.
They should both be working and by removing the key from the ignition, you will have closed the program cycle which then is complete.
Apr 17, 2010 | 2008 Lincoln Navigator
How do i set up the channels in order bbc 1 bbc2 etc to match the buttons on the remote 1 2 3 ect its a LG 42 INCH TV
selact menu on remot cantrol and see on the screen tunig menu in chenal edit to selact .
frist selact ch for edit and set your chennal no 1 /2 or 3......after the selact no prees OK key to fix your fureat ch. in your selacting no.
EXP:
ch . pisesion 36 [BBC1]
edit ch No 1
then prees OK key and see your BBC! is ch no 1 on your remot.
Oct 30, 2009 | LG 42LC2D 42 in. LCD HDTV
Automatic tuning from new only brings up RTE1 & 2. How do we get the TV to tune in all the other stations. We are in Mayo and it seems that the Freeview is not working. Would appreciate your help,...
hi
press menu key on remot cantrol and selact your contry tuner system
EXP: USA / CANADA /SOUTH AFRICA / UK ./CHINA / INDIA ..and after selact contry. set chenal Auto serch and see all chenal is perfactly set
Oct 30, 2009 | Hitachi L32H01 32 in. HD-Ready LCD TV
Look like the image is divide on three.red,blue,green .yesterday was normal.my son finish video game and turn off.Today I turn on and the image cannot show all colors together.
this is a normal problum pls. check remot cantrol on menu key press then selact convergen seting see on the screen canter three cross line arrow to set UP / DW/ LIFT/ RIGHT key maeching 3 line and see cross line is White then see the pictuer is ok
if not working convergen seting then spare STK replace in inside your tv set
Oct 29, 2009 | Sony KP-61HS30 TV
Nokia N72 Cellular Phone Logo
161 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
