Motorola Eliminators: GP300 Battery Eliminator 2-Way Radio
Problem for Motorola Eliminators: GP300 Battery Eliminator 2-Way Radio
Neither radio will receive or send
By towkie on Nov 24, 2007
I have a set of FR50 Motorola Talkabouts.  One is working OK as I have another set of Radio Shack two ways and they will work with one of the Motorola.  The other Motorola turns on OK but will not receive or transmit. When you push the call button on the good unit you hear a click on the one that is not working correctly, but that is all.  Any idea as to the problem and is there anyway I can repair?
motorola radius gp300.neither will trans or rec.there is no connection between both.ptt pressed in the red light comes on .and when you key up either set there is no feedback not a whimper.there is on both sets,on the display window a speaker symbol with a line through it.are these sets muted or do they need programming for back to back opperation ...thanks for your help.STEFAN. s wales uk.
Solution #1
posted on Jan 11, 2008
Not Rated)
petedcurtis
Rank: Apprentice
Rating: 84%, 3 votes
Motorola Talkabouts usually a have a CODE you can set for each channel. This is like a TPL / DPL code. If its not set the same for both radios then other radio may not receive.
GP300. Assuming they are programmed to talk to each other, ie RX and TX of each on the same frequency or they may talk through a repeater and that the TP/ DPL code are correct. If you have the Speaker icon crossed through they are probably muted, but in this case you should be able to unmute them from the keypad. Only other thing is if they are programmed for Selective Call, then they would only unmute on a call which contains their ID #. There several Selective call systems, MDC, Select V , Quick call are just some. Europe usually opts for a certain type of Select V. US uses MDC.
Was this helpful?
Yes
No
Popular Solutions for Motorola Eliminators: GP300
Questions and Unsolved Problems for Motorola Eliminators: GP300
Do you recommend Motorola Eliminators: GP300 Battery Eliminator 2-Way Radio?
Answer
Answer
cdm1250 ignition on wire radio stays on wired to ignition on fuse.
Answer
weak transmission dj-180
Answer
programing memory for ALD-24T
Answer
how select low and hi power 1w and 25w
Answer
how do i fix rubbber gasket coming off the front of MT975
Describe your 2 Way Radios problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top 2 Way Radio Experts
Top Telephone Repairmen
in Burnsville, MN
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
