Question about Whirlpool Refrigerators
No light in the fridge
We have a Whirlpool Gold refrigerator and recently the light went out on the fridge side. I replaced the bulb, but the light did not come back on and the digital reading for the temperature will not light up either.
  • 26 Answers
Your eloctronic control board is bad within the fridge compartment.advised to call a service tech to fix the problem as some units can be a hassle to repair on your own
Posted on Jul 30, 2009
Lights are not working in the refridgerator. Freezer lights work. Replaced switch,still no lights
did you replace the bulb? what you can also check, and the likely cause will be the socket itself. unplug the fridge from the wall outlet, remove the bulb from the socket. you will see 2 copper tabs, on e on side, one at bottom of socket, bend these slightly toward you, to ensure they contact bulb. replace bulb, plug back in and check. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lights in fridge side are all out. After changing bulbs, sounds like a relay sticking and will knock out all lights in fridge unless we loosen off the bulbs in the fridge side
your main control board Part#4334000 is defective in lower left rear of unit remove it from the white plastic box and underneath it will have a burned spot on the printed circuit trace get it at appliance parts pros 1-877-477-7278
Sep 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge Light - you posted
Your bulb is shorted out internally. Try another bulb. Please post as as helpful if so.TY
Jan 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light out and weird sound
check the wiring at the light bulb socket for a loose conection
also check the center connector of the light socket
Jun 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Whirlpool Gold side by side SR2659325
are you hearing a hum then loud click hold my rating till we are done
Mar 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
147 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
