SOURCE: Lightning Damage
There are millions upon millions of electronics that could have been fried. If you wanted to try and frankenstein with other broken receivers from ebay you might be able to fix it. Also check to make sure there aren't any fuses and I recommend a surge protector.
SOURCE: my lg tv was damage by the lightning can it still
Only someone who can look at it and see what was damaged can tell us that. Lighning is so unpredictable it is impossible to tell what got damaged and what is good without seeing it and touching it and testing it. There is always hope in these cases but to be on the safe side you might want to call the insurance adjuster. My personal guess is that it probably fried at the very least the power supply and could have traveled around in side the boards and ruined them all. But like I said it could be a very slight hit and only a small pico fuse on the power supply could have gone bad, so call the insurance folks and see if they are willing to pay for a repair estimate or will they replace the set.
SOURCE: SCHEMATIC DIAGRAM OF TV SHARP MODEL NO.14V-L70M IC
check the screen voltage g2 is approx 300vdc to 360vdc,over supply voltage on g2 (screen voltage can cause power to shut down automatically.
SOURCE: TV hit by lightning. Will Best Buy replace without questions?
Ask and see but I would not mention the lightening---if its 3 months old the LG warranty should cover the repair or replacement.
They will not know at all it was lightening unless you tell them.
"This thing just stopped working" they will either get it fixed or get you a replacement set.
SOURCE: Univerum tv control memory ic
I THINK WHAT THEY MEAN IS YOU NEED TO TUNE IN ALL THE STATIONS AND ALSO SET ALL YOU ,COLOR, BRIGHTNESS
CONTRAST , VOLUME . THIS IS THE SETTINGS YOU WOULD LIKE . SO WHEN YOU PUT YOUR TV ON NEXT TIME ALL THE SETTING WILL BE CORRECT TO YOUR NEEDS
