Question about RCA D52W19 52" Rear Projection Television
RCA D52W19 52, Squealing noise off and on from back of set
I have the same problem. I have read that you can poke around the back and see if the transformer/coil or somthing is loose, then put some silicone or glue on it...
  • Rommel Cana
    Rommel Cana May 11, 2010
    is it OK now? did it work?
What is the noise how is it caused
Posted on Aug 14, 2009
I have an RCA DLP tv model HP50LPW52. the sound was there with no picture. since it is 5 years old I replaced the lamp for the first time. got it all hooked up, turned it on and the tv slowly came on....
That is your Color Wheel that is bad. I wish you would have posted the problem before buying a lamp. I would have told you to treat yourself to a new set instead of putting good money into a DLP set that is 5 years old.
Feb 10, 2011 | RCA Televison & Video
RCA D61W20 has become a big useless decoration
I know exactly what is wrong with your TV I charge 315.00 in my shop to repair here i get paid 0$$$$
I get paid $50.00 up front to look at set and then determine what the problem is Defection board 125.00 plus 190.00 labor - 50.00 repair cost 265.00 plus tax SSB board 325.00 plus labor/ wondering can you solder if so start out by resoldering everything on Deflection board solder all pinns on Flyback transformer squealing noise is caused by coil in high voltage area LL037 resolder it then take glue gun and glue on top and around it. all so check second ribbon connector that feeds over to SSB board make sure it is installed good and there is 3 capacitors that go bad on same board 2200uf 16v two 220uf 35v located in front of board they are green with gold writing you can try all of this or order new Deflection board 1-800-648-6657 union electronics's
Oct 01, 2008 | RCA D61W20 61" Rear Projection Television
Rca parts
Yes and unfortunatly it failed taking out all the parts again. I'm back to square 1 trying to figure out the fix for this. RCA recommonds you replace the deflection board which is on international backorder and doesnt appear to be available anytime soon. I need to get back into the set and poke around with a multimeter and osilliscope see if I can't pinpoint whats causing it to blow parts back out.
Sep 02, 2008 | RCA D52W19 52" Rear Projection Television
Squealing noise
a shop will need to do the repairs on the tv..its not something a novice shouldd try to repair
Aug 29, 2008 | RCA P52926 52" Rear Projection Television
Rca f36645
A squealing noise generally indicates that there is something loading down the switching power supply. Generally a shorted component will do that. Without any other information it's hard to tell which circuit could be the culprit. It may even be a faulty power supply itself. Was there any problem prior to this condition? Any odd picture problems, shrinking etc. or sound issues, tuning issues?
Aug 27, 2008 | RCA F36645 TV
RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
May 29, 2008 | RCA F36650 36" TV
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Squeak
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Mar 01, 2007 | RCA 27F650T 27" TV
RCA D52W19 52" Rear Projection Television Logo
153 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
