Question about Philips 150B3T 15" Flat Panel LCD Monitor
Specks of dirt inside monitor
My NEC Multisync LCD 1560NX has a couple of irritating specs of dust or dirt behind its face plate. Is there anyway of getting inside to clean this? (I tried unscrewing the five bolts in the back, but was unable to lift it off the front. Seemed like something else was holding it.) As hmbhmb says, this is not a problem with dead pixels. We know what dead pixels look like, and it's definitely dirt. Is there a way to safely get behind the screen, and how would you go about cleaning it and removing the dirt specs safely without adding more dirt or problems?
36YearVet
  • 24 Answers
SOURCE: Specks of dirt inside monitor
From the sounds of your problem, you have a few dead pixels. This is a problem that can exist in LCD displays that have not been quality tested or have been damaged in some other way. If the unit is still under warranty, I would see if it could be exchanged for another monitor. Short of replacing the LCD screen, you would only be left with the option of living with the aggravation. P.S. The main reason you couldn't get the monitor apart is due to the fact that there are plastic clips mated with indentations in the other half of the housing that must be released before it will seperate. They are about every 4 inches around the entire seam of the two halves. Hope this helps.
Posted on Oct 04, 2007
tvtechnician
  • 105 Answers
SOURCE: cobwebs in the screen
pop the front grill off and you will see some screws onthe bottom of the screen. pull these out and the grey trim peice should pull right off.
Posted on Oct 14, 2007
SOURCE: Philips 50p8341a 50 in. projection
i have a 60 inch all i did was take the tub off of the back and use a duster to remove all of the webs and then use a dust free cloth and some windex and clean the bulbs
Posted on Dec 09, 2007
salt56
  • 373 Answers
SOURCE: magnavox 60'' rear projection screen tv
That oil is glycol and is a coolant for the tube. Hope you didn't get the oil on the circuits because it is conductive and the tv will not operate with the oil on it. Must be completely full. Can be bought a electronic parts distributors or a tv shop could order you a bottle. Hope you just removed one tube only. Make sure you seal it back good
Posted on Dec 30, 2007
jdbouncer
  • 72 Answers
SOURCE: dead pixels?
If they are dead there isn't anything u can do except order a replacement panel, or get a new TV.
Posted on Apr 30, 2008
My NEC MultiSync LCD 1765 monitor boots up to the lowest resolution available. When I attempt to correct the resolution through the Display Options in my Control Panel Settings, I set it at the highest...
Try connecting the NEC to a different computer, to see if it correctly accepts 1280-by-1024.
If so, then there's nothing wrong with the monitor, and the fault lies with either the video-adapter in your computer, or something messed-up with your installed copy of Windows.
Try replacing the video-adapter.
Dec 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Hi I just bought 7 NEC Multisync LCD1550v monitors and they all have the same problem. when plugged in all i get is a blinking power light. 1 of them showed signs of life for just a second but that was it....
You buy a new LCD Monitors, now still not working., if that new LCD Monitor is OK, then check your VGA Card, its inside the CPU maybe its broke or not connect properly inside. This are the cause of not displaying in your LCD Monitors.
If you here some beeps of your CPU then find out how many beeps and tell us here immediately.
Aug 03, 2009 | NEC-Mitsubishi MultiSync LCD2170NX (Black)...
Green light is flashing and screen won't come on
Try another monitor on that computer and see if it boots up with video. If you still get the same problem then that means there is something wrong with the computer. If you get video this time then that means there is something wrong with the original monitor.
On your original monitor, make sure there is no bent pins and that the cable is connected properly.
At least this way you will know whether its the computer or monitor.
If its the computer thats the problem that at least go ahead and try to take out the memory and CPU and put them back into there respective slots and blow some air onto them so its not a spec of dust or dirt that is affecting the video.
Jul 17, 2009 | NEC MultiSync 1760NX 17" LCD Monitor
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
Oct 04, 2007 | NEC 1560M-BK 15" Flat Panel LCD Monitor
Mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 22, 2007 | NEC 1560V+ 15" Flat Panel LCD Monitor
Philips 150B3T 15" Flat Panel LCD Monitor Logo
182 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
