Question about Sony NWZ-E438F Digital Media Player
Full battery, doesn't start up
Battery went flat last night, charged it over night, everything was fine, the connected screen was working correctly, it said it had full battery, so i unplugged it.
Now whenever i press a button it brings up the "Walkman. Every moment has its music" screen, 1-2 seconds later it turns off.
Tried reset button, tried plugging back into the computer (it turns on while plugged in, and can still access all files).
Not entirely sure what else to try, any ideas?
  • chucktr May 11, 2010
    You may have inadvertently answered a question I have on these Walkmans. It is stated in the instructions that you are NOT to Reset, Hibernate, Wake-Up, Power-on or Power-off the PC with the player connected to it. Since you did an "over-night" charge, did your PC go into any kind of savings mode?? Personally, I don't see how this can cause a malfunction IF you are only charging it. I could see a problem IF you were transferring songs or pics or a video, but not just when charging. I had my PC go into Hibernate mode once with mine connected. I "woke-up" the computer and so far it, the Walkman, is still working... connected or disconnected to the PC.
    Problem Solver:
  • 7 Answers
Mine is doing the same thing, and I've tried the same solutions as well as trying different computers and cables to recharge.
The one other possibility for mine is that I damaged it using a generic charger in the car that was supposed to work for "most" MP3 players. It did seem to - I mean, the player didn't blow up, catch on fire, or stop working! - but a day later, it collapsed. Maybe a coincidence, maybe damage from the car charger.
I'm guessing that it's time for both of us to send the units in for battery replacement.
Good luck with yours.
Posted on Aug 10, 2009
Canon powershot a3300
If nothing is wrong with the camera, the battery is placed correctly, the battery cover is closed correctly then only one thing can be wrong. Even when you don't believe it is possible, the battery can be flat again.
So to make sure everything is as you think. Charge the battery again, and look if the charger acts as usually. The charging lamp turns orange and charging begins. When the charging is finished, the lamp turns green. Last time you charged, it could have taken 4 hours, before the lamp went green. If the battery is recently charged, it only will take a fraction of that time. If it still takes a long time, your battery was empty. It is recommended, to charge not longer than for 24 hours. After charging, please wait till the battery is cooled down. Then insert it again and close the battery cover. Check the cover closes correctly. And now switch on again.
If you charged with an USB cambs connected to the camera. Don't forget to remove the cable, because the camera won't start as long as an USB cable is connected.
Feb 25, 2014 | Cameras
2006 Ford focus zx4 St..replaces the alternator last night car ran fine all day I came home for lunch and then I went to leave to go back to work about 35 min later and the car would not start wouldn't...
Make sure battery has a full charge. With everything off, use digital multimeter leads across battery posts, the generic spec is around 12.6 volts. Leave the leads hooked up, have helper turn key to crank, what is the reading? If the circuit is closed to the starter, shouldn't drop below 9.6 volts, some makes and models, it shouldn't drop below 10 volts. You get the picture, if drops way low, that won't work.
I'd have to check generator output and battery.
Apr 11, 2017 | Cars & Trucks
Check Charging System/told not the alternator
Check your battery connections - where the cables connect to the battery posts AND where the cables connect to the starter/main power feed and where the ground cable connects to the engine and/or frame. A poor or corroded connection can cause intermittent problems and poor charging performance.
Mar 03, 2017 | 2003 Ford Expedition
I turned my smart book on today and it came on then went blank
try rebooting in safe mode and do a restore if that doesn't work probably going to have to reinstall your OS,,, if it does let you in run scan disk under properties by right clicking on hard drive under my computer. if any of this works make sure your anti virus is up to date
Nov 01, 2012 | Sylvania Synet7wic-bk-z2 Netbook
2010 Z1000 in Australia. bike was 100% fine less than a week ago, got it out last night and it wouldn't start. The dash lights up, but doesn't show neutral light when it's in neutral. Also the...
get the dealer to sort this out as taking it apart yourself could invalidate the warranty. its classed as third party interferance, and as you are not a kawasaki mechanic they could wash their hands of the warranty.
Sep 08, 2011 | 2010 kawasaki Z1000
I replaced the battery 3 weeks ago and everything has been fine. My wife drove around everywhere on Friday. She did not drive the van yesterday. It is now Sunday night. My wife went out ot start her van...
Your alternator is going bad. It should only put out 13-14 volts and therefore is overcharging your battery. This causes your battery to get a dead cell. If you replace the alternator and battery, make sure you check the cables for any shorts.
Aug 31, 2009 | 1991 Ford Aerostar Extended
While driving late last night, all gauges went dark. Needed to replace a battery this morning, still no gauges working and replaced a 2nd battery. Batteries keep draining and still no gauges. All fuses...
DID U CHECK THE STARTER TO SEE IF IT IS GOOD!!!MAKE SURE THE WIRE IS CONNECTED REAL GOOD TO THE STARTER TOO!!! B/C IT WILL DRAIN YOUR BATTERY!!! THE SAME WITH THE ALTERNATOR IT TOO WILL DRAIN YOUR BATTERY!!
Jul 06, 2009 | 2000 Nissan Pathfinder
Screen light defect?
I had a similar problem after removing battery on my e800. After battery full charging and after PDA resetting everything was OK again.
Sep 11, 2005 | Toshiba e330 Pocket PC
Sony NWZ-E438F Digital Media Player Logo
170 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
