Question about Westinghouse Refrigerators
I have burnt the crisper in my fridge, wondering if I can get a replacement for it.
    President:
  • 2,559 Answers
Yes you can,and if you supply the make and model,We can assist in locating the part.
Posted on Jul 30, 2009
Hi I have Westinghouse freestyle 450 my problem is that no matter how low I have temp the begs freeze in crisper other wise been very happy I have had this fridge for 20years
fridge settings work in reverse to freezer settings
1 for a fridge is almost freezing where it should be around 4
cold air sits at the bottom of the fridge so the setting will be colder in the crisper draw that at the top shelf
May 26, 2017 | Westinghouse Refrigerators
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Food freezing in crispers in ge bottom freezer fridge
Check to see if the fan is working...put a thermometer in the refrigerator and make sure the temps are between 33-41 degrees F.
Dec 18, 2013 | GE Refrigerators
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
CONDENSATION ON BOTTOM SALAD CRISPER SHELF OF A WHIRLPOOL INTERGRATED FRIDGE
cold,damp air,condensates on warm shiny surfaces(bathroom mirror),try putting kitchen towel under the crisper...(why they put crispers on bottom of fridge instead of on top of the cooling coils at the top of the fridge ???)
Mar 29, 2010 | Refrigerators
Gsl25jfpa bs fridge is warm on top and frozen on bottom and freezer is warm
It sounds like the fan in the freezer is not working , to circulate air , and the coldness is just dropping . This will cause the icemaker to stop working first , then the top portion of the refrig next . As this coldness drops , the lower portion of the fridge ( crispers ) , will freeze . The main control board , causes the fan , not to run . Part Number WR55X10656 . The main control board , is located , behind the refrig , behind an 8 " X 10 " , small panel . There is usually a burnt resistor on the board , which is connected to the fan . Unfortunantly , the whole board will need to be replaced . It is easily replaceable . Doesn't take any special knowledge . All the plugs 6 or 7 , each fit the pin plug designed for it .
Oct 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Broken crisper roller tracks on KitchenAid frdge md# KBRS22KFWHO
fixya doesnt sell products or replacement parts search on line using make and model for part or notify manufacturer for a parts distributor in your area
May 18, 2017 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
19 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
