Question about Kenmore Washing Machines
Have an error masage in my washer kenmote elite f35 waht its the problem
    Brigadier General:
  • 3,513 Answers
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor.
It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure. To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. The analog pressure sensor is shown in the second image below. You can see the location of this component in the first image. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component. If you find no problems, then you will likely need to replace the component.
You can order the part from the Sears PartsDirect website. Use your full model number to access the parts list diagram for your model of washer and order the correct part.
Thank you for contacting www.Fixya.com
Posted on Jul 30, 2009
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
I am getting both the SUDS and F35 errors on my Kenmore Elite HE3t steam washer. How can I check the drain filter to clear any debris or build up?
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Jun 03, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
Code F35 on Kenmore Elite HE5t front loader washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Has code F35
I just got the same error code F35 and sometimes it says SUD. Help pls Kenmore HE5 Steam Washer.
Nov 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Sud/F35
if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
