Question about HP Pavilion a785c (82916061390) PC Desktop
Y computer will not start. I checked the power
Y computer will not start. I checked the power source and it is fine. could it be the motherboard or could it be something else? What can I check before spending money on a new motherboard?
    Sergeant:
  • 168 Answers
First, check out the power supply. With the plug out (from the wall, the motherboard and anything else the power supply is connected to). Reconnect to either the hard drive or the CD/DVD. Take the big plug that went to the motherboard, insert a paper clip between pin 14 and ground. (pin 14 is a green wire, ground is any of the many black wires) Plug in the wall power cord. The fan in the power supply should spin normally. If it does, that tells us that the power supply is working. If not, your search may be over.
If the power supply is working, unplug from the wall and remove the paper clip jumper. Then, remove anything connected to the motherboard, CAREFULLY LABELING everything EXCEPT- - -the connection to the front panel switch. A couple of pictures may be a good idea. Reconnect the power plug to the motherboard and the little square plug (4 wires). Plug in the AC and push the switch. If the power supply fan does not turn, it is a safe bet that the motherboard is the problem. If it does turn on, shut it and start adding one item at a time to the board until the problem recurs. That will be the offending part. Ram may need to be added in pairs.
Make sure to unplug from the wall between each step.
Posted on Jul 30, 2009
  • 615 Answers
Dear Sir,
According to Your problem.
Solution is here
By analysing your problem it seems to be problem with SMPS(Switch Mode Power Supply)it is the power supply part. I think your Computer SMPS is dead,so check with another brand new SMPS. I think it solves your problem. If it is not back with result and more information i will try to assist you in a better way
good luck
Fixya Customer support
chandrashekahr
    Sergeant:
  • 173 Answers
Some tomes reset bios solve this issue.
So you can reset bios with cmos cell.
Remove cmos cell from motherbord for 5 minutes then refix it .
Also reconnect smps ATX power code to motherbord .
Also check your smps is working fine.
Some times smps has issue may be your motherbord has not issue.
  • 742 Answers
A. check you casing's power supply. if your motherboard's led is lit when the unit is plugged to wall's outlet, then power supply is ok. you can check it in other way using tester or what.
B. Try to unfreeze your cpu. open the case and remove all expansion cards. try to remove the harddisk as well. try to turn on the system with all these stuffs removed ESPECIALLY the hard disk. if it's ok...then you are good.
C. lastly, if B wont work, try to transfer your RAM module to another similar slot. if you have two RAMs, exchange their slots and ty turning the sysytem ON.
    President:
  • 2,049 Answers
Try booting from a rescue CD to see if the harddik is the culprit.
If you don't have one, try making one using instructions found at
http://www.help2go.com/Tutorials/Windows/Create_a_Windows_Boot_CD___Rescue_CD.html
Be sure to set Boot sequence to CD-rom in Bios.
My Samsung RV511 Laptop isn't getting power.
Most likely problem in this instance is a loose dc socket. it is a cheap fix or you can re-solder it yourself, if you have the ability.
Nov 26, 2012 | Samsung Rv511-a01 Laptop
We have a Viewsonic Optiquest Q9B-2 LCD monitor with built in speakers. Worked fine and all of a sudden wouldn't power on. We checked power cords and changed 3-470 caps, 1-330 cap, and 1-10 cap. Monitor...
Probably not yet. Check and replace the power transistor on the source board , it has been surely fried when the capacitors failed. If even after that the source doesn't start then the transformer has been fried.- you will have to replace the entire power board. This will cost you around $75. If you think your monitor is worth that much money then go ahead, replace the board.
If not...
Oct 05, 2010 | Computers & Internet
My HP Pavilion a1050y won't boot up.
So you've checked the supply, but you didn't replace it, right? Sounds to me like that's your culprit. It's not able to supply the current to run the processor (the biggest draw) and the output is dropping too low to run the system. A new supply should get you running again.
Mar 06, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
Computer won't start
try to reseat the hard drive and the ram also try to find if power is passing on or not please check the computer by opening the ram and then restarting the computer if beep then ok if no beep then mother board gone bad.
Mar 21, 2009 | Computers & Internet
Cooked motherboard
Personally, I've never seen a monitor damage a motherboard. Since monitors have their own power source, the HP answer of the monitor "drawing too much power" is bogus.
Possible failures could include the following:
  1. Failing Power Supply - if you haven't tried a different power source, then that is the 1st thing I'd look at, expecially if another system will run the monitor.
  2. A peripheral item, (Keyboard, Mouse, Printer, scanner or other USB device is preventing POST completion of boot completion.) try booting system with just video and power, nothing else.
  3. Check the monitor cable for bent/broken pins. I have seen bent pins on a cable connection short out a video card, this could cause a no post if the video is integrated.
  4. I just reviewed the HP site on this system, and it appears to ship with a PCI-E video card. It appears most likely that the Video Card (If one is installed). If you have the PCI-E video card in system, remove it, and connect to the intergrated video connection and see if ystem posts.
Feb 08, 2009 | Envision 19" Widescreen Flat Panel LCD...
Hello, I have an E-machine D4362 that has started intermittently shutting down. I did some troubleshooting & found the CPU and case fan not running while the machine is up & running, the CPU heat sink was...
POWER CONNECTOR ON MOTHERBOARD HAS GONE BAD. CHEAPER TO REPLACE BUT CHECK MANUFACTER TO SEE IF UNDER A WARRENTY.SOME WILL GIVE CREDIT ON A NEW BOARD.
Nov 29, 2008 | Computers & Internet
No Power to Motherboard...
Here are some steps.
Attach the monitor in your CPU and plug it, see if the monitor powers up. If it did, then no problem in your power supply,
Detach the RAM or Memory of your CPU and put it back in, in the different slot. and power up your computer.
Check the cpu power switch if it is correctly attached to the motherboard.
Oct 26, 2008 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Computer will not start
1.1st check the power supply
2.check the processor
Mar 04, 2008 | Gateway (4000635) Motherboard
KV7-V power supply
follow the power cable from the PSU to the motherboard and see if the 21 connection has melted to the motherboard. You are better getting a 500W silent type, but it depends on the peripherals you have installed, try www.ebuyer.com for various makes.
Oct 09, 2007 | Abit KV7-V Motherboard
HP Pavilion a785c (82916061390) PC Desktop Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
