Question about Dishwashers
Maytag dishwasher MDBTT60AWW
Dishwasher wont start, panel lights up for wash selection but wont start when you press the start
  • 4 more comments
  • BillBB May 24, 2008
    I am having the same problem. My dishwasher is only a year & a half old. I can change the cycle and those light up fine. It won't do anything when pressing the start button. I check the door switch and it's fine. I put in a new CPU (at a cost of $96) and that didn't fix it. I went to look for the tech sheet under the toe isn't there. If anyone has a tech sheet that they can fax me or e-mail me I would appreciate it. (fax 410-374-1537, email If anyone has any other ideas I'd sure appreciate that also.
  • DianainJax Dec 31, 2008
    Maytag dishwasher (model mdbtt60aww)
    The lights for heavy wash, light wash and rinse only light up when you press them. The light for normal wash and start (the two I REALLY need) will not light up. I can select heavy wash, but it will not start when I press start. Course, the dishwasher is now full and needs to be run! I am not a Ms. Fixit by any stretch of the imagination. Any advice?
  • Anonymous Apr 21, 2009
    number 3 stays on unit will not start
  • Anonymous Mar 15, 2014
    no lights on start panel
  • Anonymous Mar 18, 2014
    Buttons will not let me select cycles and the dishwasher will not turn on
  • Anonymous Mar 19, 2014
    Dishwasher is not starting,although the light is onMy dishwasher won't start,after pressing the programme selector, the green light does not select my desired cycle,and it won't start.
  • 83 Answers
If you can select different cycles such as rinse only and that light up and then if you change it to normal cycle and it light up,then that tells me you touch pad is working,Check your door switches if those are good and your touch pad is responding, i would replace cpu board.If you remove the kick plate there should be a tech sheet there you can put unit into diagnostic mode with a certain key dance if your touch pad is responding.
Posted on Nov 25, 2007
I had the same problem with mine only after around 1 year of service. luckily i had a 2-10 warranty and it was covered. technician came out and to me he wasnt a technician. he was a parts replacer. i was assuming since it was under warranty he just replaced the keyboard, the cpu, and about 2 days of "troubleshooting" as he called it. I probably could have just gotten a new dishwasher for all the time and parts he replaced on it. Now im having problems with the latch handle that is broken. $20 for a piece of 4 inches of plastic. I think this dishwasher is just a common dishwasher for contractors to install in new homes.
Posted on Jul 18, 2008
You will need to replace the control panel, about a $200 part.
Jun 27, 2017 | Maytag Washing Machines
Power is to the dishwasher put it wont turn on
hello first check yor breaker make sure not tripped.
next check for lights in your panel.
perform a normal wash if no luck
next perform a service diagnostics cycle.
note sercice diags. works on Maytag MDB7600 series.
press the following keys in less than 6 secs.
HeatedDry > Normal > HeatedDry > Normal
to advance machine cycles press Start/Resume key.
May 22, 2014 | Maytag Dishwasher
Maytag MDB4651AWS Dishwasher will not start.
Do you ever hear the fill solenoid click on to begin the filling. That is the first thing that has to occur. The water supply generally connects right to that solenoid. Ohm out the solenoid coil. ( breaker power off)
May 21, 2012 | Maytag Dishwashers
Maytag dishwasher mdb7100aws is flashing clean-lightwash-heated dry
I have a Maytag MDB7100AWS which suddenly started blinking the following LEDs: Clean, Rinse Only, Regular Wash, Tough Scrub and Heated dry. Tried cycling the breaker, no help. Tried the key sequences in the troubleshooting sheet behind the kick panel, no help. Then happened to press the Drain/Off button twice. All LEDs went out and am now on my second successful load, fingers crossed. Suspect the control board got latched up somehow.
Jan 25, 2012 | Maytag Dishwashers
Quiet series 300, Model # MDBS561AWS. Power to control panel comes on. (lights up), But will not start.
If you are able to select a wash program but Start does not function, then most likely the door switch is not making proper contact. Check the door switch item 4 in this diagram.
Sep 03, 2011 | Maytag MDBS561AWS Stainless Steel...
My maytag quiet series 200 wont do anything when I press the start button. there are no lights. I have tried tripping the circuits?
Mine would not start, and could not set any options. I read online to try resetting by pressing Heated Wash, then Heated Dry, then repeat both. I did it and my machine cleared and worked fine. Give it a try!
Dec 13, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Wont start..light wash lights up and delay wash lights up but start button wont work. replaced handle and it worked one time
There are two micro-switches just inside the handle mechanism that apply power when the door latches. You need to remove the interior panel to access. Hope this helps!
Jul 26, 2010 | Maytag Dishwashers
ck your door inter lock . if latch is problem then panel won't work . ( you may have a panel problem . some times the ribbon wher it connects to the pc is not making good connecton .. ****
Dec 23, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag MDBTT60AWW rumbling/noisey
most of the noises you are talking about happen often when something is down in the sumpyou need to take the pump apart and you will find something small in there causing the noise! i see if very often and common for this unit.
May 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDBH950AWS Dishwasher won't start
We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
Thank you.
Jan 17, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
1,767 people viewed this question
Top Dishwashers Experts
