Question about Olevia LT42HVi 42 in. LCD Television
Olevia LT26HV LCD TV won't turn on
The TV would shut off while watching. Now it won't turn on. The blue light on the power button goes on and off when pushed, however no picture.daveserge@hotmail.com
  • 9 Answers
Olevia has problems with the power supplies. Best solution is to remove the back of the TV. On the 542 it is about twenty number 1 phillips head screws. locate the power supply connectors check the board for the voltages, clearly marked on the PCB. Continue to check the voltages by powering on the Television. all voltages should be within its described range. If a voltage is low or nonexistent, the power supply is bad, usually a bad capacitor.
There are three series of caps, on the low voltage side it is 16 volt, next 24 volt and finally 36 volt (these are just max ratings.
which ever power that was found low the cap would be near that voltage output connector.
next step is to remove the board and replace the capacitor, using a soldering iron and making sure to solder with no slop.
with the board on an insulated (nonconductive surface connect the board to the televion. Check voltages and if no other voltage issues reassemble.
Posted on Sep 05, 2009
  • 50 Answers
Check tv remote control batteries.
Posted on Jul 30, 2009
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I have and olevia 26 in tv..when i try powering the TV on.. shows blue input screen for a split second and picture goes out to black screen..not sure if still have sound but...i hit power button again blue...
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Cpacitors are less than a buck a piece typically if you order online from a place like www.digikey.com plus shipping, and they usually arrive next business day.
Jul 13, 2011 | Olevia LT26HVX 26 in. LCD Television
My Olevia 237-s12 TV won't turn on. When we push the power button, the blue power light flashes on/off repeatedly. We have unplugged the TV to reset the system but no change. Is it shot?
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps in solving the problem.....
May 07, 2011 | Olevia 237T 37 in. LCD TV
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Syntax Olevia LT26HVE, powers on, blue screen w/ sound
I have an Olevia LT26HV power is on stay blue, sound ok, but no display.
Dec 30, 2009 | Syntax LT26HVE 26 in. HD-Ready LCD...
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT42HVi 42 in. LCD Television Logo
984 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
