Question about Sharp AR-C240P Printer
Sharp AR-C240p change yellow toner counter still say's 0
I have an Sharp AR-C240p I change the yellow toner but it still say the counter is 0 any help.
    President:
  • Sharp Master
  • 1,447 Answers
Please dear your yellow toner is not original, so you change it or buy original thanks
Posted on Jul 30, 2009
How to solve an U2 error on sharp 5316
http://olsonbros.com/sharp/support/sim.html
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication error
Jul 27, 2014 | Sharp AR-5316 Laser Copier Black OEM Toner...
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
My ar-c240p sharp printer prints very nice sharp prints both color and black sometimes. Most of the time it prints light gray and washed out colors. This may happen from on print to another within...
Hello.. Generally when this happens the developer rollers are worn out and need to be replaced. This is a job best left to a trained tech. Thanks for choosing fixya! Regards, Joe
Nov 13, 2009 | Sharp AR-C240P Printer
How do I get to the black toner reading on a Sharp AR-M257 copier
Hold down the Copy button and you should see a readout for the total copies printed from the copier and the percentage of toner left in the unit.
Aug 28, 2009 | Sharp AL 800 Copier
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
May 20, 2009 | Sharp Office Equipment & Supplies
Sharp AR-5127, the error code U2-40
Try clearing it with a p*c* 16 . If not clear, CHange the toner, it has a defective crum (counter chip) on the back of it.
May 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Ar-5132 sharp copier
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
[C] – [INTERRUPT] – [0] – [INTERRUPT]
Type in 1 4
Hit [PRINT]
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
Jun 05, 2008 | Office Equipment & Supplies
Sharp AR-C240P Printer Logo
117 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
