Question about KitchenAid 24 in. KUDP01DL Built-in Dishwasher
KitchenAid dishwasher loss of power
My KitchenAid dishwasher has lost its power. We tried switching the breaker switch off and on. This did not work. Nothing lights up. It is dead. It wasn't making a noise. The only thing I can think of is a power surge as we have had storms.
    President:
  • 1,865 Answers
Electrical storms can burn out electronic components. Consider investing in whole house surge protection.
If you need assistance in selecting or installing surge protection on main power line, email me buffalonymann@yahoo.com
Posted on Jul 30, 2009
Dishwasher stopped working mid-cycle
Make sure you have power to the unit. Check the circuit breaker.
May 15, 2014 | KitchenAid 24 in. KUDI01FLSS Stainless...
KITCHENAID DISHWASHER STUCK IN WASH CYCLE
It can be the issue with defective float switch. The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. One more thing, if your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jan 16, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
I cannot change cycles and the dishwasher won't turn on.
Micro controller problem. Take help from authorized service center help.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Child lock blinking on a Kitchenaid ultima diswasher.
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
Feb 04, 2010 | KitchenAid KUDR25 Dishwasher
Breaker is on yet I get no power to dishwasher, that was working fine just days ago. is there a reset switch on the dishwasher itself?
Open your control panel. Inside the panel on the right side is a thermal fuse.part # 8269213.Replace it.
Mar 28, 2009 | KitchenAid Dishwashers
My KitchenAid Superba won't run, no lights, nothing
turn off the power at the breaker and let it stay off for at least one hour
Dec 17, 2008 | Dishwashers
////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid 24" SS dishwasher
the first thing to check is power. check your breakers to see if any are tripped. if so turn it off than on some breakers do not reset if you just switch them to the on position. also check if it has a plug or shut off switch in a cabinet nearby .
Dec 31, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwasher not working - Cancel light flashing
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Nov 27, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 24 in. KUDP01DL Built-in Dishwasher Logo
897 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
