Question about Video Game Consoles
Plantronics pulsar 260 ps3 help
Is it possible to connect plantronics pulsar 260 to my ps3?
0 characters
1 Points
I want to. use my phone as an Bluetooth for my PlayStation 3 how can i connect them both
You would need a PS3 compatible APP to operate your phone as a PS3 device. This is possible but I have not seen one yet. The sound and data of Bluetooth cannot connect to the PS3. Possibly as a qwerty keyboard.
see this link:
Can connect my cell phone to PS3 via bluetooth
Also look at this link for connecting:
How to PAIR Playstation 3 controller with any ANDROID Device
Feb 17, 2015 | Video Game Consoles
My ps3 p90 plantronics headset can't establish connection
Can you be more specific? Are you getting error messages? Anything
Jul 29, 2011 | Video Game Consoles
I can't get internet connection
Try connecting the PS3 using an ethernet cable if possible, first. This will allow for the PS3 to connect to your router initially.
Also, try restarting the Wireless Router or Modem and then Restarting the PS3. You may have to enter the IP Address and DNS manually at first, but then the PS3 will remember the information and be able to access the internet connection automatically.
Hope this helps. If not, feel free to message back and I can walk you through other options.
Mar 10, 2011 | Sony Playstation 3 (PS3) Console
I'm trying to purchase first strike and I keep getting an error code 807100092 for PS3. How do I fix this it was fine this morning I have the 250 or 260 gig PS3
Most of the time this error has to do with your internet connection. I would suggest you power off you PS3, unplug the power from your router for about a minute, plug it back in and give it a couple of minutes to boot up. Power up your PS3 and try your purchase again. This solves the problem most of the time so give it a try. Take care and good luck!
Mar 03, 2011 | Sony Playstation 3 40GB System Console
Controlers will not connect to ps3
connect them by the cord if this doesnt work than try connecting them to another ps3 to find out if its the controllers or the ps3. i have only encountered one instance where the controller just died and wouldn't work. it is rare but possible. hope this helps.
Jun 14, 2009 | Sony Playstation 3 (PS3) Console
Get disconnected from game when bluetooth is attached
lol faygit dumshet bluetooth sux get usb headset idiot. get a fockin better connection and better mic
Mar 04, 2009 | Sony Playstation 3 (PS3) Console
Controller and consolle
You can try hard resetting the controller.
Flip the controller over, and press the reset button. It's to the right of the middle-top screw ps3_controller_reset.jpg. You'll need something like a paperclip, toothpick, or something similar to push the button. Once you've reset your controller, connect it to your PS3 with a handy USB cable, and press the PS button (just like you did when you first got the controller). Now, it is paired again, and you should be OK.
I've read that not allowing the controller to die will help prevent this, so try and keep your controller charged 16x16_smiley-very-happy.gif
If that doesn't work, another issue might be your cell phone and bluetooth headset (especially if you have the headset also connected to your PS3). Try turning off the headset, or if you use the headset on your PS3 as well as your phone, turn off your phone's bluetooth adapter. I was having this issue when I was using my Plantronics headset with my PS3 and cell phone.
Got this info from Kaivarri.
Let me know if that helps, if not let me know and I'll give you some more tips. Please don't forget to rate.
Feb 23, 2009 | Sony Playstation 3 (PS3) Console
yes it is the ps3 is not reading the change tho so its an easy fix you just need to reset the connections i have done this alot on the front of your ps3 the power button press and hold it for 20 to 30 sec. it will beep a bunch then the connection is reset then try your new connections , the ps is suapose to read that but sometimes it don't it happens.
Nov 18, 2008 | Sony Playstation 3 (PS3) Console
Some bluetooth headsets have been known to not link up after the playstation has been turned off, or if the power goes out. You may have to redo the linking process again to make it work. Some headsets this has to be done every time the playstation is turned on. Another possible scenario is that the plantronics has on/off and a bypass function when its turned on. If you turn on the headset, try tapping the on button again and see if it links up.
Hope this helps.
Apr 05, 2008 | Sony Playstation 3 (PS3) Console
PS3 -Connect to Internet using PC with wireless Broadband Card???
Yes you can but you need a router or ou need to connect the ps3 directly to your lan card the just set up a shared internet connection through windows
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles Logo
Top Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Video Game Console Expert? Answer questions, earn points and help others
