Question about Kicker Solo-Baric L5 Car Subwoofer
Bad sound while playing at low volume, tested both voice coils and they are both are around 4 ohm.
Do you have it wired down to 0 ohm or 2ohm if u have a mono block amp wire it to where a pos. from one side goes to a neg on the other side and then use a pos an neg from diff sides coming from amp
Posted on Jul 30, 2009
I have Teac SL-D80 radio, CD player. One of its speakersLeftdoesn't, work.How to fix it? replace the speaker or wire?Thank you!
Unplug unit.
Open casing.
Look for loose wiring connector, otherwise:
Temporarily swap left and right speakers.
Plug in and play a continuous recorded tone of about 50Hz-440Hz.
Play with maximum volume to get a decent voltage reading.
If LEFT CH now works then L speaker is faulty.
If RIGHT CH now works then L amplifier is faulty.
Electrical test (needs a meter with Volts and Resistance).
With speaker still connected test audio (AC V) signal on working right speaker terminals.
Now check left Channel at amplifier board if possible, and at speaker terminals.
If no V unplug speaker wires if possible at board then test across board L+ and L- output pins.
Still nothing means amp is faulty.
Test continuity of speaker wires end-to-end. Each wire should be 0 ohms or close to zero. The continuity buzzer function can also be used for this.
With amplifier off and unplugged, remove speaker-connector from board or cut live speaker wire or unplug lug at speaker, whichever is easier. With one wire apart from the amplifier, test the loudspeaker ohms.
Should be in the range of about 4-8 ohms.
Most speakers have the rating screen-printed on the voice-coil magnet housing.
If ohms reading is way too low, say 0-1 ohm it has a short and is damaged.
If ohms reading is way too high, say several Meg-ohms, it has a coil break and is damaged.
Carefully join/tape any cut wires if applicable, renew speaker if faulty with same size and rating, re-test then re-assemble.
Dec 18, 2017 | Cars & Trucks
Brand new volfenhag 15 1500 wattsblew on 1200 watt amp why
There are a couple of reasons why this might have happened. Subwoofers are finicky. I always recommend to my clients that you don't apply full power to your sub until you have had one week of playing it at low volume. This helps to condition the voice coil. When at full power the voice coils heat up rapidly. To go from cold to heat fast will warp the coil. The bad news is that this would fall under the "abuse" category for refunds. Then again, you might get lucky with a return unless you bought it from an individual. The other thing might be how it was wired. If your amp is 4 ohm stable and you wired to a 2 ohm load, it may have shorted something. But you would think that would be the amp. Not sure this answered the question, but just a few ideas to think about.
Aug 16, 2011 | Volfenhag ZX-4715 Car Mid-Range
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
I cant sem to wire it to 4 ohms because the terminals are right next to each other and i have no clue which 1 is which voice coil?
test with a digital multimeter set to ohms. if you don't have one of those laying around grab a 9 volt battery and run wires from the 2 terminals on the battery to 2 of the terminals on the woofer. if the woofer pops out you are said to be "in phase" (even though it has more to do with polarity that phasing but regardless) which means the positive from the battery is on the positive of the woofer and the negative is to the negative. those 2 terminals on the woofer are a single coil and obviously the other 2 terminals are the 2nd coil. now depending on what impedance each coil is will determine how you have to wire it to be 4 ohms unless they are 4 ohm coils which means you just use one coil and it will be 4 ohms on that woofer.
Aug 18, 2009 | AudioBahn AW1205N Car Subwoofer
Speakers won't play ''loud at all '' Just Very faint
they dont sound loud because you need to use the DUAL voice coils and make it 2 Ohms. Google " how to bridge a dual voice coil sub"
May 25, 2009 | Infinity Reference 1052W Subwoofer - 10"...
Sound problem
Make sure all speakers that are hooked up sound ok. If any of them sound lower then the others or sound distorted you may have a speaker with a partially shorted voice coil. If speaker or speakers pop when power is first applied you may have a grounded speaker that should not be grounded. Each speaker wire rides on 6vdc and if any speaker sees a ground you will have 6v across voice coil which would explain any popping noise when first turned on and radio may play for awhile then overheat. be sure speakers are 4 ohm min per ch otherwise amp will run to hot. Just a few Guesses
Jan 13, 2008 | Denon AVR-1708 Receiver
12w3v2 Started making distorted bass noise at low volume
Connect each speaker coil one at a time to a square 9 volt battery and watch for the cone to move.
Also try hooking another speaker to your amp just to make sure the noise isn't in the amp.
You can use a 9 volt battery to test wire polarity also. Hook up the + wire of the speaker to the + terminal of the battery and the - speaker to the - battery terminal. If the speaker moved UP or OUT then the wiring is correct. If it moved IN or DOWN then the + and - wires are backwards on the speaker.
Also if you have two or more speakers hooked together test all the same way while they are hooked to each other. ALL of the speakers need to move in the same direction at the same time.
Clipping causes more speaker damage than anything. "Dirty Power" can happen in good quality amps too. The gain control is to match the voltage between the headunit and the amp. It is NOT a volume or boost knob. If you overdrive the first stage of the amp and then clip it damage will occur to the amp and speakers at some point.
Hope this helps.
Jan 04, 2008 | Jl Audio 12W3 Car Subwoofer
Installation
Hi JJerky,
I suggest we go for 2 ohm to preserve the amp and not heat things up so bad.
Your Subs are Dual Voice Coil(DVC) and 2 ohms each coil. I am going to tell you the wiring to insure you get balanced response from both Subs. We will wire the Subs Voice coils in Parallel to make them 1 ohm each. Then we will wire the Amp to the subs in series to make the total load on the amp 2 ohms. When you have series to both subs each sub gets the same current.
Example of my coding :SUB1VC1+ = Subwoofer 1 Voice Coil 1 Postive terminal.
SUB1VC1+ to SUB1VC2+
SUB1VC1 - to SUB1VC2-
SUB2VC1 + to SUB2VC2 +
SUB2VC1 - to SUB2VC2 -
AMP + to SUB1VC1 +
SUB1VC1 - to SUB2VC1 +
SUB2VC1 - to AMP -
This should give you a good repsonse.
Adjust your Bass Gain down very low at first. Also cut you LPF to about 60 hz. Crank up the volume on a bass test Audio track, Adjust the Bass Gain up unitl you get distortion. The turn it back a little. This is proper setting for your Gain.
Dec 01, 2007 | Lanzar OPTI1222D Car Subwoofer
Amp?
Make certain that each ouput channel from the unit is driving no more that 4 ohms each. If you have more than one speaker attached to an output then be sure they are wired in series NOT parallel. Two 4 ohm speakers in series is an 8 ohm load and the same two speakers in parallel is a 2 ohm load. If the speakers are dual voice coils then you must treat each voice coil as if it were another speaker when it comes to wiring.
Aug 16, 2007 | iLO XM-MP3-CD Car Stereo
How should I wire up this amp and sub
The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
Jun 10, 2007 | Kole audio Q2-480 Car Audio Amplifier
Kicker Solo-Baric L5 Car Subwoofer Logo
112 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
