My friend of mine has a problem with his laptop TOSHIBA Satellite A10-2416 while booting, it has a display and then when Windows has been loaded the screen becomes flicker until it run out with no display on screen and it has grey display but when you connect the monitor or the external display it has display.anybody can help me about this problem to fix it!
Comments:
Nov 26, 2007
- Sir I cheked the wirings inside the LCD display I haven't found any damage with the wirings, when the driver of the display is not yet installed the display is ok, but when you installed the display driver the display went out.
-   Yes, I have the same problem with my Gateway Laptop. When I turn it on only a yelloish white display appears. But when I connect it to a monitor then I can see everything that should appear on the LCD. I have checked all the wirings and everything.
My Toshiba satelite has done this 2 times now I was on-line and for no reason I got a blue screen...
(More)
My Toshiba satelite has done this 2 times now I was on-line and for no reason I got a blue screen and then it shut down. I tried to reboot but I get 3 lights on the key board and the power botton light up it sounds like it is thying to boot then the lights flash 4 times then powers down?
I have an A105-s4211 and the lcs screen is messing up, it'll fade out to a cloudy black screen, but...
(More)
I have an A105-s4211 and the lcs screen is messing up, it'll fade out to a cloudy black screen, but when i press on the side of the screen and the front to sort of bend the screen the picture comes back on and works perfect, but asoon as i let go, it stops working and slowly goes back to the cloud, any idea's what might be the problem?
