Question about LG Vu CU920 Cellular Phone
My LG VU wont charge anymore and its not the charger or the battery because i have replaced both and no luck. When i plug it in the screen blinks a couple times then the screen just goes black.
Mytouch lg wont power on is their a way i can power it on without power button
did you try plugging it in the charger and then press the power button when its charging? if its able to do that then that means your phone battery has been worn out and cant be charged anymore. youll need to buy a new battery
Apr 04, 2013 | Reiko Wireless Pouch Protective Carrying...
When plug in the charger phone turn itself off then says insert battery and it takes for ever to charge the handset
Here is what is going to happen next, just so you know. You will have to remove the battery completely. Then, plug the phone into your charger. It may take a moment, but it will tell you to insert the battery. Once done, you can charge the phone normally. But, here's what will happen, if my experience is any gauge. Next your screen may stop responding, so I suggest you back up your contact list as soon as you can. After this, you will most likely need to replace the phone, as the problem these phones are having just doesn't seem to stay gone. I have a replacement phone now, and for some reason, my battery will not keep a charge anymore. So, I am going to have to purchase a backup battery. Let's hope you have better luck and only have to do the first part of this fix. Good luck.
Oct 22, 2009 | LG Vu CU920 Cellular Phone
Battery will not charge correctly. When I plug it in, it says it is charging but it isnt actually charging because it never gets the "battery complete" stage anymore and when i take it out, the battery...
I have the same issue. I found out its because Im using a generic charger. If your using a cheapy try buying a OEM charger. That should fix the problem. Im trying to figure out a way around it. Will post back if I find anything.
Oct 05, 2009 | LG Vu CU920 Cellular Phone
My LG VU turned off and wont turn back on
Take out your battery wait a couple seconds and return it then try turning it on again still if it wont turn on take out your battery and plug in your charger with the battery out if it works your battery might have blown up or something also u could possible try it with your battery in and your charger pugged in
BestWishes                  -SunShine-
Jul 04, 2009 | LG Vu CU920 Cellular Phone
LG Vu Wont chrge correctly
Your charging port is probably going bad. It seems to happen fairly regulary on the lg VU
you can get it repaired or get a workaround external battery charger.
Check out the following link for your options.
http://www.chargemyphones.com/lg-vu-wont-charge/4/
Jul 02, 2009 | LG Vu Cellular Phone
My LG VU charges just fine sometimes, and other times it will say its charging and drain the battery, and other times it wont register that its charging at all.I have 2 house chargers, and one car charger...
well about the arrows being upside down, some phones like this one the charger goes in up side down like for example the katanas. But about the charging issue check in the back of the phone and look for a red or white sticker or maybe pink. if its red then thats indicating that it has been water damaged and if its white then that indicates that if might not be but if you look in the charge port and check if it has like some green and white corosion in it. If you would like some help with this just e-mail me at Purelatina2004@yahoo.com
Jun 15, 2009 | LG Vu CU920 Cellular Phone
Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
May 13, 2009 | LG Vu CU920 Cellular Phone
Something is either work my my charger or the phone for the lg vu. a few days ago, the charger worked fine but for some reason its ot working but the red dot on the charger is on; when i plug it to my...
It is loose now the charging port may have gotten broken. It happens with the LG VU's.
If this is the case, you have 3 options.
1. repair -warranty preferably
2. new phone
3 or external battery charger. cheapest option
Check out the following link for more information
How to Charge LG Vu with Broken Charge Port
Mar 07, 2009 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
290 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
