Cell Phones Logo
r
rose mcshane Posted on Dec 27, 2017
My voicemail has been turned off & I need it putting back on asap.
dwood429
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 12 Answers
  • Posted on Dec 27, 2017
dwood429
Contributor
Level 1:
New Friend:
Night Owl:
Answers
12
Questions
0
Helped
23352
Points
35
You will need to contact your voicemail/phone carrier customer service to help resolve this issue. They should be able to help. Here are some common carriers support numbers. If yours is not listed; feel free to search for more on the internet:
T-Mobile: 1-877-453-1304
Sprint: 1-888-211-4727
Verizon: 1-800-922-0204
AT&T: 1-800-331-0500
Hope this helps.
I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
Question edited for clarity.
This phone system has two features.
Answerphone system which records messages to the unit.
and
Voice Mail System which is an extended (often paid) service from your telephone provider.
Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.
Page 32 refers
https://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdf
Retrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply.
Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically.
Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33
Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone.
My provider says I need to turn off voice mail on my phone so they can provide vm service. How do I turn it off?
  1. Dial your own phone number and wait for your voicemail greeting to start playing.
  2. During the greeting, press the * key (star key) to interrupt the greeting.
  3. Enter your voicemail password or PIN if prompted.
  4. Follow the voice prompts to access the main menu for your voicemail.
  5. Navigate to the option to turn off voicemail (sometimes referred to as deactivating voicemail).
  6. Follow the prompts to confirm that you want to turn off voicemail.
Note: If you're unable to turn off voicemail through these steps, or if you need further assistance, contact your service provider for specific instructions.
If you still want to access your voicemail messages, you can do so by calling your voicemail service directly. On most phones, this can be done by dialing *98 or by pressing and holding the 1 key on your phone's dial pad. You may also be able to access your voicemail through the phone's app or by calling your service provider's customer support line.
I KEEP GETTING A MESSAGE EVERY 10 MINS SAYING I HAVE 2 VOICEMAIL MESSAGES WHEN THERE IS NO VOICEMAIL MESSAGES.
Call your phone company and ask them to reset your voicemail.
Also pull the battery out of the phone while the phone is turned on. Walit 30 seconds and put the battery back in and start the phone.
Sep 05, 2016 • Cell Phones
1helpful
How do you get rid of a voicemail sign showing that you have one.when you don't have one
Call from alternate line, leave a voicemail and then from your phone go your voicemail, listen to it and delete it after listening to it complete, power off your device, remove the battery and sim card, put it back in turn it on and that should fix it.
Sep 22, 2011 • Cell Phones
1helpful
3answers
Voicemail icon is blinking and I have no messages
Aftre checking twice to ensure I truly had no remaining phone/text/etc. messages (i.e. not initially trusting the "you have no voicemail" lady), I still had the blinking Voicemail Icon on my Verizon (Casio) GzOne Boulder. I turned it off and on, and it simply went away. Reboots triumph again. Since most of us leave our phones on 24/7, betting many don't try a repower/reboot. This is also way less risky than having some new Tech Support person mess with your account ("remove voicemail and put it back on", per the above comment). Until they have less buggy software/firmware, simply reboot.
3helpful
2answers
Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
2helpful
Unanswered calls will not go to voicemail
Ok, do you know how to get into system programming?
If you do:
-> get into programming
-> TERMINALS&SETS enter and put in the extn that is giving you issues
-> then under CAPABILITIES look for FWD NO ANSWER and put in the DN of the voicemail you saw with the Feature 985
-> hit next for the number of rings you want it to ring before going to voicemail
Voila, that set will now goto voicemail.
Voicemail
Voicemail is part of your Service Plan. Contact your service Provider and tell them to remove that feature.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
