Question about Hisense TL1700 17 in. LCD Television
Hisense TL2020 - Won't come on.
When turning on the unit the light just flashes from red to green to red to green but the TV does not come on. None of the switches on the TV work and the remote doesn't work either. Have disconnected power and reconnected with no results. Have changed batteries in the remote with no results. Have turned the unit on and off with the switch with no results. No matter what I do the light just keeps flashing and it will not come on. Is it time for another TV?
  • fquattro Mar 01, 2011
    I pulled out the (3) 1000mfd electroitics but they were all three 16V NOT 25volt and I don't see a 220mfd at all. Should I replace these three with new 16 volt or new 25 volt electroitics???
    Thanks for the assistance.
  • Anonymous Mar 25, 2014
    I have changed batteries,but still won't work The red light stays on can't change channels with remote,it does nothing,can this be resolved
  • 11 Answers
Lay unit flat on table, remove stand and rear cover. When you remove back, you will see a power supply board in the middle of the set.There are (3)1000mfd @25 volt electroltics and (1)220mfd @16 volt electrltyic that have to be replaced to return to normal operation. This is not something to try if you are a novice as you must observe polarity when installing these caps. But this repair WILL return set to normal operation.
Posted on Aug 08, 2009
  • lmsail Nov 27, 2010
    VIP154:
    This help was great!! Had this TV with similar problem, perhaps caused by a power surge. Replaced 3 caps in power supply and now works great. Thanks very much for you advice.
    Larry
This works. I replaced only the (3) 1000mfd . I bought them for $1.58 at Radio Shack along with an $8 soldering gun and $2 worth of soldering wire. I got away with paying less than $20 in supplies. I bought the TV for approx. $250. This fix was well worth the trip to Radio Shack.
Posted on Jan 03, 2010
  • rdogs62 Mar 01, 2011
    could you post picture(s) of the location of these caps? i'm having a hard time identifying which are the ones that need replacement.
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
Screen pulses white. off and on, lite on front goes from green to red. model is Hisense TL2020
that problem is usually cause of shorted fly-back transformer that give a very high voltage you can find that by hanging all secondary connection of fly-back then power it again then use your multimeter and range it to dc then ground the black prove to the body of your unit test the b-plus voltage if the supply is flickering it means your fly-back is shorted and if the supply is stable it means you have a shorted diode in secondary thank you
Mar 05, 2011 | Hisense TL-3220 Television
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
Hisense Remote Control won't work
In trying to program a universal remote for my Hi-Sense TV, the TV locked. How can I unlock it?
Oct 23, 2008 | Hisense TL1700 17 in. LCD Television
Hisense TL2020 It does not turned on.
check your power output if ok replace your mainboard
Sep 19, 2008 | Televison & Video
Compatible hisense tl2020 to program a remote control
CALL TIVO SUPPORT TO SEE IF THEY SUPPORT THAT MODEL IF THEY DO THEN THEY SHOULD GIVE YOU A CODE
TiVo Customer Support
Live agent support available: Monday - Sunday
7:00 AM - 8:00 PM Pacific
Phone number: 877-367-8486
Mar 24, 2008 | Televison & Video
Hisense TL2020 TV repairing
To unlock your Tl2020 with a universal remote just go into the menu and select V chip setting. The password from the factory is four zeros (0 0 0 0 ). Once you get in you will the letter "B" nect to everything. Set everything to the letter "U". Then, turn off the television. The set should be unlocked now. Good luck !
Frank
Sep 15, 2007 | Hisense TL1700 17 in. LCD Television
Hisense TL1700 17 in. LCD Television Logo
2,396 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
