Question about GoVideo Go Video DVD/VCR Combo
I have a Go Video/Sonic Blue DVR 4400 which has DVD and VHS, I have never recorded VHS to DVD can someone please tell me how to hook it up so I can record to DVD. Also can I use TDK CD-R disc to record on
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
  • 1003 Answers
SOURCE: Go Video Unlock Code
check the menu settings or (setup) on the dvr 4000 to see if it has options to enable or disable parental lock or to change region settings to region 1.
also the dvds you made are they +r or -r on what brand dvd record disc on dvd-r this may solve the problem but use a quality brand disc like memorex dvd-r it is compatible with many players and recorders also make sure the disc you made on the recorder were finalized.
Posted on Jan 15, 2008
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
  • 105 Answers
SOURCE: Recording from dvr to vhs
Check/replace the cable from DVR VIDEO OUT to VCR VIDEO IN
Posted on May 03, 2008
  • 4 Answers
SOURCE: go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
Posted on Sep 26, 2008
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Can't record from Cable DVR
Here is a diagram of an option for you to hook up a cable box, to a VCR, then a TV. I took out all the other things and kept it simple. You can always hook up more later. The cable should go straight into the DVR as it is, then hook the yellow A/V cables from the DVR/cable box output to the VCR input then anther set of A/V cables from the VCR out to the AV1 on your television.
You will have to select the A/V input on the Go Video, then you should be able to see a picture. The only drawback on this option. You will have to watch what you record.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Televison & Video
Connection/configuration issue: I have a Denon
Just confirming my understanding of your connections :
1). The DVD1800BD output HDMI is connected to AVR3808's DVD-in HDMI.
2). The DVD/VHS recorder output HDMI is connected to AVR3808's DVR-in HDMI.
3). The DVD/VHS recorder input (S-video and L/R Audio) is connected to AVR3808's DVR-out(SVideo and L/R Audio).
Right?
What other inputs have been connect to your AVR3808?
Does the recorder have Component Video inputs?
Please also connect DVD1800BD's output(Component video, S-Video and L/R Audio) to AVR3808s' DVD-in similar inputs and try recording onto your recorder.
Actually, its possible that you may be having a HDMI HDCP communication issue(High-Bandwidth Digital Content Protection) with the source product (DVD1800BD). First check with the source equipment manufacturer for any updates to their products.
If HDMI video is not passing through your AVR3808, you can connect it thru the alternate connection method I have mentioned above.
If the connections/recording still does not happen with the added anolog cables, then let me know , we can trouble shoot it further.
I hope the above helps.
Please do rate this solution and thanks for using FixYa!
Mar 06, 2009 | Denon AVR 3808Ci Receiver
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
Apr 06, 2008 | Sony RDR-VX555
How Do I hook up my Sanyo DVW -7000 To my Dishnetwork Box to record?
Connect the "Out to TV"video and audio on the DVR box to the "Video in and Audio In" on the VCR ...unless it's a single screw type connector on the DVR then hook THAT to the "In from ANT/cable" on the VCR
Sep 08, 2007 | Sanyo DVW-7000 DVD Player/VCR
Hooking up (properly) a vcr to dvd recorder and recording
could be cause there is a copy write protect on the vhs
Sep 02, 2007 | Ricoh (5125a) DVD±RW Burner
GoVideo Go Video DVD/VCR Combo Logo
459 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
