Question about Garden
Cub cadet wont start. changed plug, fuel filter, checked fuel lines. starter engages but engine wont fire. what should i check next?
    President:
  • 1,865 Answers
A safety switch may be preventing startup. Jumper out safety switches and see if it starts.
Posted on Jul 30, 2009
I have a cub cadet 7260. It ran out of diesel and I can't bleed it to get it to start. It's a 1998 model
I don't now the cub worked but diesels, should a plug or screw on top of fuel filter. first make sure your fuel tank is 3/4 full. lo. pump ose screw wait till fuel run out. close screw. if your lucky you have a fuel pump pump it up till feel pressre. PUMPING IT SLOW CRACK A INJECTOR LINE TILL FUEL COMING OUT. CLOSE LINE AND GO TO NEXT ONE AND NEXT
Jul 23, 2017 | Cub Cadet Garden
I HAVE A CUB CADET 173CCOHV SELF PROPELEDWON'T START NEW PLUG GASTO THE CARB AIR FILTER OK STILL WON'T START
I would check to ensure the coil is firing. You can do that with a plug tester attached between the plug wire and the plug and check to see if there is fire to the plug or remove the plug and ground it to the motor and see if it fires as the engine is rolled over. Hope this helps.
Oct 24, 2016 | Cub Cadet Garden
Cub cadet lt1050 starts but after mowing for awhile i shut it off it wont start again
be sure the air fins on the engine are clean. make sure the fuel line is away from heat source. loosen the fuel cap and see if it starts. sometimes if the cap don't vent it will not let it start. change the spark plug. check to see when it does this if it still has spark. the coil may be going bad.
Oct 05, 2016 | Cub Cadet Garden
My rtz 50 will not start I have changed the fuel pump and filter it seems to not be pumping aany fuel. I have checked the fuel lines and can suck gas from the carburetor side of the pump thru.
Take a spray bottle and spray some fuel into the carb and see if it starts if so you have a fuel problem. If not you may not be getting fire to the plug. Check the plug and be sure it is gapped correctly and be sure you are getting fire through the plug wire.
Sep 20, 2015 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
Cub cadet tractor diesel filter plugged with nasty stuff, I have change the filter and it still wont start
First bleed it? Than you may have crack the lines hook to injectors
Oct 19, 2014 | Garden
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
My 25hp kawasakie motor cranks but wont fire. tractor model 7252. ran perfect 2 days ago. parked it now this problem. where do i start to find problem?
All internal combustion engines need three things to operate (air, heat or spark, fuel). Check to see if you have all of these things, a clean air filter with a clear path to the carburetor, spark at the end of the plug wire (this can be checked by using a screwdriver inserted into the plug wire end and holding it close to a metal grounded surface), and fuel to the carburetor (check to see if you have fuel at the fuel line going into the carb or an easier test is to spray a small ammount of carb cleaner into the throat of the carb just before cranking, if it starts and runs you have a fuel supply problem then check backwards to find the blockage (pinched fuel line, plugged fuel filter, bad fuel pump ect).
If no spark at the plug wire check all connections at electrical terminals under hood and at switches for parking brake, belt engagment (PTO) ect..
Usually if something runs and then just dies suddenly there is an obvious problem, your powers of observation will help you the most. Look at anything that looks out of place.
Jan 25, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have a cub cadet 1500 series and it wont start i changed the fuel lines feul filter spark plug i can pour gas in the carb and it will fire but there is gas getting to the carb it just wont start
Check and see if it has an anti-backfire solenoid in the front of the carb.If it does and the solenoid has power then you need to replace it.
Nov 15, 2009 | Garden
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
