Question about Nintendo Wii Console
New Wiimote not synching or being picked up by sensor bar.
O.k. so it turns out that it was just a flip of a light switch that needed to be, well.. flipped. i'm retarded. Anyways. Well, we'd been having problems with the orriginal Wiimote that we had bought when we got our system. Well one solution to some of the Wiimote problems is, just shoot the dang thing. Ten gauge double barrel side by side did nicely. Course this was after one solution listed on here of dunking it in water. Yes, that did solve alot of frustration problems. Back to the real problem. Well yesterday we went to wallmart to get a new Wiimote. It's not synching or, picking up the sensor bar or the sensor bar isn't picking it up. Whatever is going on, we don't know. I'v tried unplugging and re plugging in everything once again. Yes the light switch is flipped this time. Tried new batteries, tried pressing the synch buttont, tried... well, just everything i can think of. I like this sight however so I thought I would see if anyone could think of anything. Maye it is my sensor bar, but I don't know. If it is my sensor bar, I read that you can look through a digital camera and should beable to see blinking lights on the sensor bar. Is this fact? Haven't tried it yet but if it is the case, how many lights should be blinking on my sensor bar? Anyone have a clue?
  • 140 Answers
You must press sync in both wii (near card slot) and remotes at same time. like connecting wireless mouse and keyboards.
Posted on Nov 28, 2007
Remote not working
more info required.. do the lights come on at all, if so - synch the wiimote with the wii console while on the WARNING screen(press the red button on the wiimote & the red button near the SD card slot on the console.
If no lights come on the wiimote - you either need new batteries or you may have damaged the wiimote by dropping liquid on it or somethiing similar...sometimes cleaning the wiimote PC board with alcohol swaps may fix that, but it is not a task for a novice (you sound like a novice, so I advise against it).. Opening the wiimote and putting it back together again is not easy for a novice to get right without proper instruction.. My advice - search for videos of how to achieve this.
If none of the above work - you probably only have 2 options left..
1. send it for repair (costs almost the same as the price of a new wiimote)
2. buy a new wiimote
~Good luck
Oct 24, 2013 | Televison & Video
Tip
Broken or lost Wii sensor bar? No problem!
So for whatever reason, you have lost the use of your Wii sensor bar. Maybe the cat chewed it or you just moved and the kids are complaining they want to play a game and you have no idea what box it was put in. Either way, the sensor bar isn't as complicated as one might think. The bar is nothing more that a light of reference point. Simple. It has ordinary LED bulbs that emit a small light. The Wiimote's cameras pick up the light and with that, the Wii can figure out how the Wiimote is being held and how far you are ect. It's more than that but we're only talking about the sensor's job. With all that being said, you simply need a light reference point placed in the required position as the sensor bar. A number of things can be used from tiny lights or what I found was best, candles. Two tea light candles in place of the sensor bar 5-8 inches apart will work just fine. TRY IT FOR YOURSELF. Unlit, the Wiimote will not show on the tv screen. Light the candles and you now can enjoy your Wii again!! <br /> Hope this helps :D
on Sep 23, 2011 | Video Game Consoles & Games
After pushing A screen stuck on select lanuage, (english) pop up will not move to another screen, need to know how to escape to next step
There is supposed to be a "Confirm" button on the bottom right corner of your screen that you select using your wiimote.
If your wiimote isn't responding, this may be due to your sensor bar not working (or maybe the connection isnt pushed in all the way) OR your wii mote may not be synched up right (if you could push "A" on the previous screen this isnt the case" OR if you cant see the "Confirm" button you may need to adjust your tv's aspect ratio
hope it helps!
~good luck!
Mar 08, 2011 | Nintendo Wii Console
The remote is synched with the wii but the arrow will not appear for me to select "wii active".
If it is synced, there is probably a problem with your sensor bar. try using a different wiimote. if that fixes it, you probably need to replace the wii-mote. if not, your sensor bar needs replacing. but try unplugging your sensor bar and plugging it back in first, and try standing at different distances from the TV. Hope this helps
Jan 13, 2011 | Nintendo Wii Console
I have a nyko wireless wii sensor bar. the first one I had would not turn on, and so I got a new one but the same problem is happening. the blue light will not turn on.
First thing to check is your battery... This sensor bar is nice that it doesn't require a wire for power, but the battery tends to drain pretty quickly. After about 8-hours or so of playtime you'll probably have to change batteries.
You also need to calibrate the sensitivity if your Wiimote afterwards to make sure it works properly.
Lastly, this bar is also known to have issues with some third party controllers. If you're not using the official Wiimote you might also have issue with this bar.
May 27, 2010 | Nyko Wireless Sensor Bar for Nintendo Wii
I bought my son a Wii this past Christmas so it's not that old. The Wii remote finger pointer isn't working; however, I can power the remote on and off, use the "A" button, the home button, and use the "+"...
First you need to determine if the problem is your Wiimote, or your Wii's sensor bar.
You can check to see if your Wiimote is transmitting to the bar by looking at it through a digital camera (this allows you to see the infrared light). Turn everything on and view the tip of the remote through the camera, if it lights up: it's working, if it doesn't: you may need a new wiimote.
If it turns out your wiimote is working, then it probably means your sensor bar needs replacement. I think that is more likely (and less expensive)
Mar 29, 2010 | Nintendo Wii Console
My sensor bar does not operate, do I have to change it? Or is there something wrong with another device?
  1. Make sure everything is plugged in, although imsure you have already done this.
  2. Your IR lights might've died. Buy a new sensor bar.
  3. Borrow a mates Wiimote.
  4. If you sensor bar runs on batteries, replace them.
  5. Replace wiimote batteries.
  6. Ask Nintendo.
Nov 11, 2009 | Nintendo Wii Console
We are trying to get the hand to come up on our tv, but we have to point the remote away from the tv to get it to come up.
Here are a few things to try:
  1. Make sure that you are using new batteries. This is the number one cause of Wiimote problems.
  2. Make sure that your sensor bar and wiimote sensore are free of fingerprints, dirt and other obstructions.
  3. Try another wiimote to see if it is the sensor bar, or the wiimote.
  4. Turn the remote upside down. If the pointer on the screen does not flip, then you have a problem with the mothion sensor in your wiimote.
Oct 23, 2009 | Nintendo Wii Console
Wiimote unresponsive to anything
Have you tried restarting the Wii and then synching the wii remote to the wii ?
Just below the disk loader is a hinge you can open to insert a sd card, There is a red button - Push it
Take the battery cover of the wii remote, their is a red button - push it
Push both buttons close together time wise
Aug 12, 2009 | Nintendo Wiimote & Nunchuk Controller...
Sensor bar doesn't work
Questions:
1) Is the bar plugged into the console?
2) Did your cat or dog chew through the wire?
3) Have you tried using the setup menu to alter the remote's sensitivity?
4) Is anything interfering with the sensor bar, such as a reflective surface or other lighting in the room? Shiny coffeetable tops and fluorescent lights aren't friendly to the Wiimote. Try covering reflective surfaces and playing with the lights off.
5) If you get a replacement and still have the same problem, then the problem is with the Wiimote.
Mar 13, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
73 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
