Question about Danby Designer DAR1102W Refrigerator
Freezer works fridge not cooling on a Danby Designer fridge
I have a Danby fridge/freezer. Freezer seems to work great but fridge not cooling very well. Set to max tried notching it down it just not cool very well. It was on its back side for about 20 min when my idot friend transported it.
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Jul 30, 2009
    Novelist:
  • 108 Answers
There should be a vent between the freezer compartment and the fridge. In order for the fridge to be cold, this has to be open so that cold air can cool the fridge. I'm not sure, but I'm guessing that on that model it is simply a mechanical door operated by a dial. so you need to open any covering sheilds and make sure that the door (the damper actually) is open, and that air is blowing through. Granted, you don't want it open too wide, because then you will have two freezer sections, so you might have to experiment with it.
There is a fan in the freezer that should be pushing air... on some models the fan stops when the freezer door opens, so check holding down the door switch.
My danby refrigerator model # DFF092C1BSLDB stopped cooling, the freezer is still working fine. This is brand new
Cold freezer air is not properly being diverted to refrigerator section. Check out damper and controls for same.
Sep 02, 2017 | Danby Refrigerators
Freezer working, fridge not
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Danby Refrigerators
Danby Designer All Fridge (no freezer) Model # DFF1776WE Water pooling underneath crisper drawers. Very full every couple of days. Then it leaks out the bottom door hinge. Not sure if drainholes are the...
Yes it is located in the refrigerator on the bottom in the back. I assume you know how to clear it, Hot water plus towel to soak up excess water should take several tries of very hot water until it clears. Good luck
May 26, 2011 | Danby Designer DAR1102W Refrigerator
Unit ices in a few days after defrosting and will not cool.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Danby Designer DAR1102W Refrigerator
Danby propane fridge model # dpr2262w-6. the freezer still works great but fridge portion does not . the fridge has a bad smell. the fridge is at a cabin and no service
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 24, 2010 | Danby DPR2262 Top Freezer Refrigerator
Danby DPR2262W fridge won't cool, freezer works great
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 05, 2010 | Danby DPR2262 Top Freezer Refrigerator
A funny smell and i think it might be the temperature
Adjust the knob to 3 or 4 which would be the midway temperature.
0 would probably be off or close to it. The 7 would be coldest and freeze water.
If this is manual defrost you need to turn it off and defrost it. The frost will keep it from getting cold enough. The buildup is normal from humid warm air when opening the door. You might get a standalone fridge / freezer thermometer (about $5) to tell you what temperature is. The smell may be food spoiling from warm temperature.
Mar 20, 2009 | Danby DDW1805W Designer Series...
Fridge not working
almost certainly a compressor fault. not worth repair
Sep 02, 2008 | Danby Designer DAR1102W Refrigerator
Fridge getting warm, defost not properly working...
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Danby Designer DAR1102W Refrigerator
Danby Designer DAR1102W Refrigerator Logo
1,326 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
