Nf shows up and washer stops
NF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
It means no function or new function.
I had the same problem. You cannot use steel-braded 'never-flood" water supply hoses. You can however, use regular steel braded hoses. The never-floods have a plastic mesh screen just beneath the screw-on sleeve that somehow delays water entrance into the washer and makes it erratic. These hoses are sold by the big hardware stores, and are manufactured by third party producers, and will not work with the new front loaders. Change them out and the machine will function as per normal.
samsung vrt washer does not get all clothes wet
gasket between drum and body twisted drun hits body
Samsung vrt front loading washer
Shows doc error code
washed sheets. load noise at end of cycle. water came from under machine. now won't start.
