Question about Ryobi Saws
Compound Mitre Saw Motor turning, spindle isnt.
Compound Mitre Saw Motor turning, spindle doesnt spin. I have removed Output shaft assembly, cog turns separately from spindle, is there a key insert that makes it spin together?
  • 1 more comment
  • waymack1 Jul 31, 2009
    Ryobi 210mm Compound Mitre Saw Model CMS812
    Output shaft assembly consists of cog(teeth) and shaft, cog turns on shaft, and I dont think it should. There is key slot on inside hole of cog. Cant get these tow pieces apart, though I have removed circlip.
    Thanks for reply
    Output shaft assembly - Cog is spinning on shaft, looks like key should keep them turning together. Cant get assembly apart to see the problem.
  • David Ford
    David Ford May 11, 2010
    what is the exact model number and brand and I will check into it
  • 2,176 Answers
I have went to 3 different sites and cannot find the model number listed on them, I did look at a Ryobi saw and they indicate it is an assembly. but before I did that I would try and removing the gear from the spindle. It is possible that when it spun it put a burr in the parts and you would have to use a little extra effort to remove them I would suggest going to a repair shop and having them press them apart and see what you canfind that way. Sorry I couldn't find more for you
Posted on Aug 21, 2009
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
Power is going to the motor on my dewalt 12 mitre saw but the motor is not spinning
Does the saw make any noise? If not it could be an open circuit in the field coils
Feb 22, 2014 | Dewalt Heavy - Duty 12" Double - Bevel...
Skil 3316 Compound Mitre Saw 10"
I suspect that the brushes have fallen out between the end bearing and the armature bars.. Try removing the brushes and see what happens.
May 18, 2013 | Skil 10-in 15-Amp Compound Miter Saw...
King Compound Mitre Saw Mod.# 8370 Sawblade always comes loose. Th Blade is installed properly. What can I do ?????
This is very dangerous... There are possibilities of incorrect installation due to IMPROPER parts. Some blades use a diamond cutout for the shaft. It is VERY important that the right size spindle versus blade is used. The washer under the retaining screw should have a relief on the back side such that the washer lets the shaft protrude a few thousandths through the blade. If the spindle is round without the diamond cutout, sudden stops can unwind the screw. I have hadd that problem on a radial arm saw. I would recommend that you get some thread sealant (removable type) such as Loctite and put a little on the threads FOLLOWING directions. Make sure it is the removable type grade of Loctite. Also tighten the screw properly either using the locking pin or jam a piece of wood in the teeth to hold from rotating while tightening.
Jul 28, 2011 | Garden
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
Jul 26, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
How do you replace the blade on as Protech 8 1/4 inch compound mitre saw? i can't get the blade to stop spinning and i can only get to one side of the attachment bolt.
there should be a spindle lock on the opposite side of the blade bolt,, make sure that when you replace the blade that you install the flanges correctly and if there a spacer that it is in place.
Dec 22, 2009 | Bosch 12" Compound Miter Saw 3912
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Can you tell me what is causing my delta mitre saw motor to run but the blade does not spin powerful enough to cut moulding?
Maybe the bolt which holds the blade on is loose. If the motor is on the RIGHT side of the blade, then the bolt has 'left-hand' thread. Turn it counter-clockwise to tighten.
Jun 19, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Dewalt 708 sliding compound mitre saw
Probably a worn bearing. The only other thing that I have seen cause this is a bent spindle. This would usually occour if the machine has had an impact or if the blade has been suddenly jammed against a nail or something in the work that has caused it to jam and/or jump up.
A good indicator for bearing wear is to see how much play is in the blade in an up/down and side to side movement (unplug saw, safety first).
To check spindle, remove blade and run machine without the flanges etc on. Rest a scredriver gently on the shaft as it spins and see if you notice any (uniform) vibration.
Oct 07, 2008 | Saws
Saws Logo
279 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
