Question about Oster Health & Beauty
Bought Oster Golden A5 clippers new but did not
Bought Oster Golden A5 2 speed clippers 78005-140 new but did not receive user manual. Need to know how to prepare clippers for first use and how to change blade and attach Andis clip on guide comb.
  • 448 Answers
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
Easy. this is a flip top interchangable blade. hold the clippers in one hand, hold the blade near the edge and flip up, then slide off. Make sure the blade is oiled. turn on clipper and put a few drops of oil on each edge of blade every time you use it. To grease the clipper, remove the screws from the plate (where you see the "O" on the front.. On the inside you will see all the moving parts. Fill it up with clipper GREASE, not oil. Really slather it in there. Depending on how much you use this clipper, you should check it once a month and clean out the hair and grease it. The inner parts can be removed, just make sure you pay attention so you put them back in right. On the side of the clipper near the plate you will see a small chrome "dot". This is for OIL, put the tip of your oil tube on the dot, push down and squeeze until you see oil dripping out. do this once a month as well.
Posted on Jul 30, 2009
I just got a Oster Golden A5 and it came with it 2 tubes of lubricating oil and I don't know where or how to use it? Please help
For lubricating the between the blades and also the drive spindle.
Instruction Manuals - Oster
Shop Oster Pro. Products · Specialty · Videos. Service & Support. Product Registration · Product Support · Service Center Locator · Sharpener & Repair Locator · Distributor Locator · CA Transparency Act · Return Policy. My Account. Create An Account · Update Profile · View Order History · My Wish List. About Oster Pro.
Oster Golden A5 clipper. Basic Service - YouTube
? 11:59 Oct 27, 2015 - Uploaded by Cloud's Diamond Sharpening
Basic service. Parts needed, Link, Lever, Hinge, Latch and 2 screws. Enjoy! Lightless Dawn by Kevin MacLeod is ...
Oster Golden A5 Clippers Manual - YouTube
? 0:33
Feb 20, 2017 - Uploaded by Nada Lina
Oster Golden A5 2 Speed Clipper - Duration: 1:15. MrTryan88 8,704 views · 1:15 · NOT CUTTING? Taking ...
Jan 13, 2018 | Oster Health & Beauty
How do i oil and clean my oster clipmaster clippers
Please see user manual for this information. If you no longer have your user manual, please see link below
Oct 23, 2011 | Oster Golden A5 2-Speed Universal Motor...
I have an Oster Golden A-5 one speed that I bought 20 yrs ago. I have lost the manual and need to know if I can oil this unit and if so how? Thanks, Lorrietis
Here how you can oil your A-5 clipper, The button on the side of the clipper is the oiler, depress the button down with a small screw driver and while holding the button down, use Oster clipper oil it will take about 4 to 5 drops of oil. after you are finish wipe clean with paper towel and turn on your clipper, let it run for about 2 minutes. Turn your clipper off and you are done. We hope this will help you Thank You. Manny's Sharpening
Apr 20, 2011 | Oster Golden A5 1-Speed Universal Motor...
I have an Oster Golden A5 2 Speed animal clipper and don't know how to change the blades. I live in Australia so can't go to Oster. How do I do it please and is there a comprehensive Oster Manual? Thanks,...
hi, if you look at the blade while its attatched to your clipper, at the back edge of the blade there is a black metal peice called a Latch push this towards the blade and pull the front edge away from the clipper it will hinge away then you can pull it straight off.
As for an instruction manual if you have no luck contact us and we can send one to you.
Dec 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
Simple question: Are the Oster 76 2-speed, the Oster Crewmaster 2-speed, and the Oster A5 2-speed all the same clipper with different detachable blades?
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Oct 03, 2009 | Oster Golden A5 2-Speed Universal Motor...
Where do I put the oil in my oster a5
across the blades were they contact each other.  WD40 works fine.
Mar 07, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 keep turning themselves off whilst I'm clipping
Ok turn your clipper on and hold it still in one hand whilst with the other hold the cable near the end of the clipper and bend it, rotate and twist if your clipper cuts in and out you have a break in the cable which is tricky to fit but our web site Help section can help.
Feb 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Health & Beauty Logo
556 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
