Question about Canon Office Equipment & Supplies
My PC11 will stop after printing one copy and the letter ''P'' shows up. what is the ''P'' for?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
P stands for paper ,the machine needs paper
Posted on Jul 30, 2009
MY hp laserjet 200 color m251 pcl 6 do not print full copy of A4 when printing via internet or wireless pls, i need a setting to make it print full copy . thank you.
I would check to ensure that the page size of both the driver and the printer are set to A4 and not letter. Most HP's will auto sub letter for A4 but if driver thinks paper is letter when it is actually A4 then the printout will not match.
Sep 16, 2016 | HP Color LaserJet Pro 200 M251nw
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
KONICA MINOLTA ERROR CODE CALL C0070 MACHINE
Problem with toner bottle motor
After
a reset problem, remove the bottom cover back and PC11 toner sensor block cover. And release the locking lever bottle, turn the bottle 1 / 2 turn recontact PC11. The bottle turns she released the lever?
May 25, 2011 | Konica Minolta DiALTA Di200 Copier
There is a message showing on My Canon MX310 "Check Printer 5B00", how do I fix it? Right before the message showed up I copied a document that printed with a line down the middle.
Try these procedure:
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Canon PIXMA MX310 All-In-One Printer
I Have a Toshiba E-studio 200 copier that I have connected to my computer network. It has been working fine Printing invoices and letters. Then all of a sudden it has stopped printing invoices and...
Go into the network menu of the copy machine and check the assigned "ip" address. If your copy unit is set to dhcp then all that might be wrong is that the address has changed...you print to the asigned adress that gets set up on the copyer...
Apr 14, 2010 | Computers & Internet
I have a new photosmart C4680 printer and I can only print one copy at a time from my computer. I want to print two or more copies at a time. What do I do to make this happen ?
Usually the number of copies of a certain print job is handled by the software.
Example: You have written a one page letter using WordPad. You would like the C4680 to print 2 copies of this letter:
1) On the menu, click "File"
2) Choose "Print..."
3) On the page that follows, change the number of copies to 2. There are other options you may choose at this time, if desired.
4) Click Print
The unit should start printing 2 copies of your letter.
Jan 05, 2010 | Office Equipment & Supplies
Prints are only at 80%
make sure your paper is not set to "ltr-r"or "letter r" which is the same size paper, just turned the other way. The control panel should show you the paper size its set for, or you can turn the original sideways if the platen/target glass allows for this size. This machine is a digital copier, so it should be able to turn it the proper direction unless its programmed for "ltr-r" copying.
May 26, 2009 | Sharp AR-164 Copier
Black streaks on copies Canon PC11
Ok. You will likely need a new toner drum or cartrige. (usually you need the drum)
May 24, 2009 | Black Box (PC110C) Print Server
Won't print multiple copies
If this is a WW10 II using the code and Q will increase the impression. If this dosen't help some WD40 on the front of the print solenoid may help.
DickyO
Jan 02, 2009 | Lexmark Wheelwriter 10 Series II...
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
old marine
old marine
