Hello, Laurie -
It looks like the company Mr. Christmas is the manufacturer of Bandstand Bears. This the link to the company Contact Us web page:
http://www.mrchristmas.com/ContactUs.aspx
I recommend you telephone the company and ask about replacement parts or send them an email with your question.
SOURCE: instructions on repairing 1998 Mitsubishi eclipse
http://www.rcaz.com/rcaz/sub%20indexes/doorhandlefix/index.htm
All the instruction you will ever need..... Good luck and let me know what happens.
SOURCE: 1992 lower ball joint replacement
THE LOWER BALL JOINTS ARE A VERY TIGHT PRESS FIT INTO THE ARM, YOU NEED TO BUY A BALL JOINT PRESS KIT TO REMOVE THEM, BUT BASED ON MY PAST EXPERIENCE IT IS BEST TO JUST REMOVE THE LOWER CONTROL ARM AND HAVE A MACHINE SHOP PRESS THEM OUT AND THE NEW ONES IN, IT IS VERY EASY TO DISTORT AND RUIN THE CONTROL ARM DOING AN "ON THE CAR REPLACEMENT", THE BALL JOINT PRESS KIT RUNS ABOUT $50-$200 DEPENDING ON THE MAKER AND THE QUALITY, TRY WWW.HARBORFRIEGHT.COM TOOLS FOR AN ENTRY LEVEL KIT.
SOURCE: I have a 1999 LX470 and live in Cabo san Lucas (no
do what i do make your own ,these rubber boots are not sold separate so when i prepare a vehicle for the annual vehicle mechanical inspection i will cut some thin rubber then wrap it around and tie it up with some thin bailing wire ,or as i call it my bodgeing wire .
SOURCE: I am going to attempt to replace the front left
autozone has the haynes repair manual for 20 some bucks
SOURCE: For '92 Dodge Spirit wiper
It is a plastic bushing that holds linkage together you can get replacement bushings from auto parts store like
They can look it up in there books and get the right bushing to put it back together.
Testimonial: "thank you so very much!"
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
