How do I fix this problem !
If you need to ask how to fix it, it probably means you shouldn't be tinkering with it.
You have something that represents a fair chunk of money and it would be wise to consult an experienced horologist about your problem or perhaps consult the manufacturer.
The cure might be as simple as removing the hands and putting them back to coincide with the chimes but it is presumably a fault that developed over time. I doubt the hands moved their relative positions by themselves but rather something inside happened.
Owning a mechanical pendulum clock is a hobby that requires some basic knowledge about how it works and how to care for it. The hands should never be turned backwards, for instance. Changing the time for daylight saving means either stopping the pendulum for an hour or advancing it by an hour and pausing at each quarter to allow the chimes to sound fully. Any mistakes will mean winding on many hours or stopping the clock and waiting.
SOURCE: Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
SOURCE: Chime strike on middle of 1&2, 4&5, 7&8 and 10&11 instead of 3,6,9 and 12.
We understand your question:
The hand has a center bushing with the square hole in it.Remove the hand and use a pair of pliers on the bushing in the minute hand then re-clock or rotate the bushing back on the quarter hour then replaced it back on the clock.
Hope this tip provides some workable ideas for this repair.
R/
David
Orlando
SOURCE: Gazo Rancho Santa Fe Grandfather Clock won't chim
Check the wires in the back.some times the get corrodes.
