Question about Dryers
My frigidair FEX831CSO stacked washer/dryer has quit drying. Was wondering where the heating element is
    Scholar:
  • 76 Answers
Try to get in the back of the dryer section? If you can, i believe you can get to it from the back im not to sure, its been a while since i work on this model...to help you out better go to this websit www.partselect.com and then type in your model number. click on your model number and it should pull up diagrams. click on the dryer section and it shows where each part is located...hope this helps...
Posted on Jul 30, 2009
Replaced the element on dryer and still wont heat but will spin and washer had quit working when old element went out
Good Afternoon Friend,
I understand the washer and dryer of your Frigidaire laundry center, model# FEX831CS, are both giving you troubles. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FEX831CS Top Load Stacked...
Why frigidaire dyer model fex831cso not heating up?
Good Morning Friend,
I understand the dryer is not heating up on your Frigidaire laundry center, model# FEX831CS0. First, there are two house fuses that the dryer is plugged into. Make sure that both are good and the breaker has not been tripped. If one of the fuses is blown, this can cause your dryer to not heat. Secondly, make sure that the lint filter, lint trap area, ducting leading outside, and the outside exhaust duct are free of lint. This can cause your dryer to not dry, due to lack of ventilation. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire fex831cso
-Best Regards-
WP
Fridgidaire high capacity stackable FEX831CSO/ washer/dryer no heat
If dryer tumbles but won't dry usually means the heating element has broke in two. It can also be a thermostat usually installed near outlet of blower assembly or a limit switch installed in element heater assembly.
Jun 16, 2012 | Washing Machines
Dryer takes 90 minutes to dry ONE load. What do I need to check?
clean lint out of vent first. then check heat stats and make sure vent is not blocked or kinked. if dryer cannot vent hi-temp. heat stat. will cut power to element, when it cools off element re energizes heats up and heat stat cuts power again. this causes a long time to dry. could be other things, but this is most likely
Sep 30, 2011 | Frigidaire FEX831CS Top Load Stacked...
Dryer will not heat-up, clothes stay wet even after hours of drying! gas is on, gas bill payed,turning needlessly, no drying.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Nov 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Where to get free manual for stack washer and dryer frigidaire
I think this might be it. Please let me know if it's not right.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134809600een.pdf
Jul 09, 2009 | Washing Machines
Dryers Logo
369 people viewed this question
Top Dryers Experts
