Where is the model number whirlpool gold
Where is the model number,bought the machine in 2000 it is a top load gold series. it quit agitating and spinning
    Novelist:
  • 108 Answers
Usually the model number on Whirlpools is under the lid on a sticker... if not there, check behind the ccontrol panel
Posted on Jul 30, 2009
I have a kenmore 80 series, which I inherited when I bought my house. I noticed that the bottom of the agitator moves, but the main part doesn't. What can I do to fix it?
If this is a Whirlpool manufactured top loader (such as Kenmore, Estate, and Roper) they use a split-agitator design. In most cases, agitator slippage is caused by worn agitator dogs, a worn cam assembly, or both. This is a very simple repair that doesn't cost much, either. The following link explains: http://www.fixya.com/support/r3608577-replacing_agitator_dogs If any replacement parts are required, they can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
I have included the part number for the agitator dogs in the link provided. However, it is often more cost effective to purchase the entire cam replacement kit as opposed to purchasing individual parts. The kit usually includes the agitator dogs, cam, cam thrust bearing and replacement washers/seals (depends on the model number). The agitator cam assembly should be listed under the agitator parts listing. If you have questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Apr 26, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Whirlpool Top Loader Estate Series Washing Machine and the agitator will not spin properly?
Good day,
Most models used a split agitator. If your describing the top part, then an Item called "dogs" has failed. Yes that's Whirlpool's name not mine.
Here's a link to get you up and running. Inexpensive repair.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
May 15, 2010 | Whirlpool GSC9455 Top Load Washer
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
Bottom part of agitator does not work, i replaced the clutch dogs two weeks ago for the top part. kenmore series 80
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are a number of Series 80 design washers. You'll need the actual model number to better check for the problem.
First, I'd remove the top agitator (as you've already done), then I'd remove the main agitator.
Under it you will see a clip and what Whirlpool calls a "washer". The "washer has two prongs, one fits into the main agitator shaft drive and the other fits in the lower agitator. If one or the other of the prongs is broken, the agitator most likely wont. I'd also look inside the main agitator to see if the ridges are broken off.
I'd then start the washer on it's smallest cycle and see if the main agitator shaft turns back and forth. If it doesn't and the washer goes through it's drain and spin cycles, the problem is likely in the transmission itself with what they call the agitate gear and / or agitate cams.
Please see the Whirlpool / Kenmore PDF document on installation, maintenance and operation of direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
This is a Whirlpool document with parts lists for their commercial washers (basically the same as the consumer models)
If the problem is in the transmission, although it looks complicated, it really isn't that bad if you have a moderate level of mechanical ability.
Sep 26, 2009 | Kenmore 22422 Top Load Washer
Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Mar 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
Agitator will not circulate the water during wash cycle
i bet you just need the agit-dogs but send me the complete model number from under the lid and i will see about helping you / larryyb
Nov 28, 2008 | Whirlpool GSC9455 Top Load Washer
Whirlpool Ultimate care II Washer Agitator not turning
replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
