Question about GE (PSS26MSRSS) Side by Side Refrigerator
Inside coils freezing up on GE 22cuft side by side
I have a GE 22cu ft side by side fridge model #GSS22IFPH WW that is about 5yrs old. I've noticed over the past year or so that the inside fan has been ramping up and down, kind of weird sounding at times. I went on vacation for about a week, came home and the fridge was on the blink. I pulled the inside panel on the freezer and the evaporator coils were frozen solid. Thawed out inside coils, cleaned condenser coils and plugged back up and it started working properly! It only lasted about 11 days and it froze up again inside. Thawed back out again and it is working good for now. I pretty much know that there is a problem with it, I just dont know exactly what. I kind of suspect the defrost heater below the evaporator, is this logical? Any suggestions welcome.
    President:
  • 1,776 Answers
Check the back of the fridge. There should be a metal panel that is covering the motherboard. If you remove the panel you should see the motherboard. To test the defrost system, you can put the unit into defrost mode by using alligator clips and wire to jump across the two terminals like you see in the one picture that I have attached. Doing this will put the unit in defrost mode and will make it easier to troubleshoot the system. While it is in defrost mode, you can check to see if the heaters on the evaporator are getting hot. If they are not getting hot, then you need to use a multimeter to see if voltage is getting to the heaters. If there is not voltage reaching the heaters, then the problem is usually caused by a bad defrost thermostat or a faulty motherboard.
Following are the pics I want you to look at. One shows what the motherboard looks like and the other shows the terminals that you must jump across to put the unit in defrost mode. Sure hope this helped and best wishes.
Inside coils freezing up on GE 22cuft side by side - 60051c7.jpg 4cf54ac.jpg
Posted on Jul 30, 2009
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
Our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Jul 13, 2009 | Refrigerators
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Cubic feet in a GE MOdel TFX22KRCE WW
If there is nothing inside the refrigerator that will tell you its cubic feet, you could always calculate it on your own. See this link:
http://www.ehow.com/how_4530599_find-cubic-feet-refrigerator.html
Jun 17, 2009 | Computer Gear Fridge Gears Puzzle
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
51 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
