TEAC X1000R Stereo Tape Desk (reel to reel)
I have a TEAC X1000R Stereo Tape Deck (reel to reel) that will not play. The fast and forward works and it still will not play.
  • 6 more comments
  • mcartym Nov 24, 2007
    please disregard, we got it to play
  • Anonymous Mar 10, 2008
    I also have a TEAC X1000R/ will go into fast-forward and fast-reverse but will not go into eiother play or reverse can anyone help me out with what I need to do/replace/etc?TNX
  • Lee Philip Schlanger Mar 10, 2008
    I also have a TEAC X1000R/ will go into fast-forward and fast-reverse but will not go into play or play-reverse...any suggestions? TNX
  • Anonymous Jun 06, 2008
    I have the same problem :(
    Fast forward works fine, as does rewind.
    Play starts out crazy slow, dies immediately. WHY
  • thouchins Jun 11, 2008
    I also have a X1000R that won't play but will go into FF RW.
    I think it's a belt issue.
    can anyone help?
  • borge0512 Sep 18, 2008
    I had the same problem. Changed the the belt, but the problem remained. It was the capstanmotor - burned. Looking for a new or used one???
  • Anonymous Mar 05, 2009
    my teac x-1000 won't stop spinnig, on the play side, it continues to run fast what can i do?
  • Sam Palermo
    Sam Palermo Oct 01, 2012
    The X1000R suffers from a condition of sticky or dried grease in the Pinch Roller pivots. This must be taken apart and cleaned and Lubriplate applied. I have done hundreds of them but then I worked for Teac at one time. I am still doing them in Chicago now. The other thing can be a decayed capstan belt and also bad tension settings. Almost all machines I get in are all set wrong out of specs increasing head wear, wear on the motors and power supply stress. It is amazing how many incompetent people there are out there adjusting these things. Of course when the machines do not work right after they get done with them I get them here so I guess I am the last stop.
Usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it
Posted on Jun 20, 2008
  • prfcg2 Feb 20, 2011
    1. As suggested replace the motor belt
    2. Clean and lube all rollers and bearings.
    3. Clean and lube the pinch rollers easily accessed from the front of the machine.
    4. Clean and lube the pinch roller shafts from behind the pinch rollers with Q tip dabbed with lubrication.
    5. Use tape lifter lever gently on X1000R to start allowing the pinch rollers to go up/down again.
  • Sam Palermo
    Sam Palermo Mar 29, 2013
    You need to take the linkage off to do the job effectively- your pinch roller linkage method is that of the consumer and will not last long.
  • Audio Player... Master
  • 1,267 Answers
That is a over simplified version of the truth. The X1000R is a very complicated deck employing a servo tension system of the reel motors- these often times get off reference and need adjustments. If the Capstan belt is to be replaced it is best done by a Technician- why is this? Because the change of any capstan related part requires the calibration of the speed adjustments on the capstan servo board. In other words- the belt just does not plug in. The Flywheels should be pulled out and cleaned and the bearings oiled- Just putting on a belt will not accomplish this. I kind of know these machines as I have been a Teac Technician from the early 80's and have worked at the Factory Service in Arlington Heights IL. I operate Skywave Tape Deck Repair in the Chicago area if you want the deck serviced correctly and with a 6 month warranty.. I repair Teac, Pioneer, Sony, Technics and Studer units all the time. I have been servicing decks for better than 40 years now.
Posted on Apr 12, 2015
My teac R-435x 1 ax works while the other does not,causing tape to slack
Maybe a stuck brake o the reel table need lubrication. These are best worked on by a Tape Deck Technician- they still do exist as I am one of them.
Aug 24, 2014 | Audio Players & Recorders
I have a Teac X1000 Reel to Reel tape recorder. The reels fast back and fast forward but when I press
This level of machine requires a service Technician with knowledge of the workings of this machine. The typical Technician will adjust it to work but often times it is a mess when they get done. There are two remaining Techs that know their stuff in the US. They are Russ Bachmann at New Jersey Factory Service. Then there is myself at Skywave Tape Deck Repair (Chicago area). Contact me if you need help in Chicago or Russ in the New Jersey or NY area. We both take shipped in units all the time. We both worked for Teac and have been doing the job since the 80's. if you need more info on either.
Nov 14, 2012 | Audio Players & Recorders
The PLAY function of my Cassette desk doesn't work anymore
Well two things have to happen to make tape move in a cassette deck. One is the Capstan shaft has to rotate and that is usually a belt link to a motor through a pulley. The second thing is you must have take-up torque. If the tape moves but the take-up reel does not pull it onto the take-up reel then you either have a eaten tape or the deck will shut off. in your complaint it could be any of these items- maybe a bad Idler from the reel motor or the capstan belt is old and stretched.
Aug 10, 2012 | Kenwood Audio Players & Recorders
Music playing backwards
Well, not being there to try some diagnostics, there can be a number of reason that the tape plays backwards at times. One reason is that the tapes are 4 channel discrete tape requiring a 4 track 4 channel deck- this would mean track 2,4 are recorded in the forward direction. A Stereo (2 channel 4 track deck) play tracks 2,4 in the opposite direction. That is why you turn the tape over on some decks. Other possibilities could be tape path skew, that reverse relay is NOT changing the head that "listens: to the tape and that is just the start of what it could be. When a new person starts to use a deck of such age- it can be correct to assume that the deck is not working in some respect. A Tape deck Technician such as myself would know how to determine if the deck was working correct or not and know and have parts to correct it. I worked in the Factory Service in Chicago for Teac and actually have one coming into my shop in the near future. After 40 years of working on these I am still at it. I am sorry there may not be an easy answer to this.
Aug 01, 2012 | Teac Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
A 303 cassette deck - the belt has been changed. The feed spool and capstan turn fine. The take up spool does not turn and play stops after 5 sec. Take up spool is fine in fast forward. Help !
This is a case of a failing reel motor. What happens i sthe brushes become aged and wear down and the motor has what they call a dead spot on the Commutator. The motor will work fine at high speeds as the inertia is working for it but when you use a slow speed as in play mode the motor hits the dead spot and stops. You will need a new reel motor in the most likely case- I can service the deck if you want at Skywave Tape Deck Repair Chicago area. I will most likely put a new motor into the deck.
Oct 04, 2010 | Teac V377 Single Dual Cassette Deck
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Audio Players & Recorders
Teac x1000r tension arms drop take up reel stops might be able to help
Jan 23, 2009 | Audio Players & Recorders
How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Mar 25, 2008 | Audio Players & Recorders
2,152 people viewed this question
