Question about Samsung Eternity Cell Phone
Hello! My phone is the samsung eternity, which has a touch screen. When i got the phone, you could switch between multitap and full keyboard when texting by rotating the phone. Now it will not allow me to access the multitap option. I have tried turning the phone off but it didn't do anything. What can i do to fix this?
I have an older Samsung Eternity touch screen phone. I would like the unlock code for it and I would like to know if unlocked would it preform on the Virgin Mobile network?
Yes, your phone can use virgin sim card after unlocked. You will need samsung eternity unlock code to perform that process and you must remember don't put wrong samsung unlock code many times in your phone, it will make your phone in hard lock condition.
Jul 25, 2011 | Samsung Eternity Cell Phone
My touch screen not working SAMSUNG A867 ETERNITY
If you have any functionality at all left to your touch screen, try to recalibrate it within the settings menu. Otherwise, remove the battery, wait about 15 seconds, then reinstall.
If that doesn't help, the touch-sensitive surface glass has gone out. Apparently, this component in the first-generation Eternity has chronic failures.
Replacing it is not too much trouble for an experienced cell phone technician. But, it's not for anyone who doesn't like to tinker with small things. Here's a video demonstrating the entire process: http://www.youtube.com/watch?v=QJpHHs9QM5U.
Jan 23, 2011 | Samsung Eternity Cell Phone
On my samsung eternity, the touch screen wont work. i can do anything but touch the screen it wont work! how do i fix it?
Hey buddy,
The issue can be with the flex of your phone that connects to the touch screen. The connection might be loose thereby disabling the touch screen functionality.
The best solution is to take it to Samsung repair shop and get it repaired by an expert. They are well experienced with touch phone firmware malfunction issues.
Thanks!
Dec 14, 2010 | Samsung Eternity Cell Phone
Hi, My Samsung Eternity touch screen started behaving weird. It doesnt click to the actual location where I touch. I tried everything I know but it doesnt work. Pls Advise
this is a screen problem in samsung.
The screen does behave wierd then it can not resond at all when phone is in hot humid weather.
Samsung must replace screen. I had the same problem with the Jet. There is a defect in the screens they used. They know it, this is a common problem.
Sep 28, 2010 | Samsung Eternity Cell Phone
The touchscreen on my samsung eternity frooze./..can not access my phone because the screen is frozen
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jul 06, 2010 | Samsung Eternity Cell Phone
I just put a new screen and face plate on my samsung eternity and the screen is working but the touch part is not working
TOUCH SCREEN
Take care
Jun 24, 2010 | Samsung Eternity Cell Phone
My samsung eternity has a lock code when i turn it on but i dont remember the lock code, how do i get it unlocked/
Hello.
The default security code for all samsung mobiles is 00000000 (eight Zeros).
If that code isn't working Try to Master reset your Phone.
Attention! must buckup all the data on phone before perform this Procedure because it format the Entire phone Memory.
Samsung Eternity Master Reset Code:
*2767*3855#
This code does a full reset. (it will wipe all data and settings).
Aditional help:
Samsung Eternity (SGH-A867) Manual Guide.
Thank you for Using Fixya.
Good luck.
Nov 04, 2009 | Samsung Eternity Cell Phone
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
Samsung Eternity  Cell Phone Logo
233 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
