Question about Digidesign Mbox 2 Pro FireWire Audio/MIDI Interface Sound Card
When I plug in my keyboard to my MBox pro 2, I see the light for audio, light up but i get now sound out of my speakers. My computer is hooked up thru firewire and is on, plus my midi works and the computer has sound thru the speakers but my keyboard has no sound. how can i fix this?
I am used compaq c700 laptop and i formet my laptop and i don't have sound drive so what can i do
Posted on Aug 01, 2009
When i plug in my mbox mini 3 the blue light come on, but when i try to lauch pro tools it says that hardware is not recognize. When look at the mbox mini control panel, it says that it is not connected...
Assuming you are on a Windows system, go to Control panel/Sounds and devices/ and check that the Mbox2 appears as the default in the Audio and also Voice tabs/panes while unit is connected. If it is not, select it in each... if it is not in the list offered, then the drivers have not been installed for the Mbox.
Aug 24, 2011 | Digidesign Mbox 2 Mini Workstation
Im having a digidesgin mbox 2 connect to my mac.. and am using a pro tools 8. But when i click records (as i had plug in the mic) there will be no signal detected tho my headphone have a sound there! And...
You need to make sure that your Protools 8 is routing the tracks to the headphone. Check that by seeing whether the M-Box is set up as your output system as well as input. Having MIDI thru has helped me with that problem before even though it has little to do with it.
May 02, 2011 | Digidesign Mbox 2 Pro FireWire Audio/MIDI...
How do i open the mbox 2 pro?
I just opened mine.. it had 5 screws on either side just under the blue plastic cover. if u want to do it nice, then just locate the screw by puttin somethin in there, and use ur screw driver to make a nice hole just above that screw. i really couldnt find an alternative way to open that damn thing.
Mar 27, 2009 | Digidesign Mbox 2 Pro FireWire Audio/MIDI...
MBox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
unfortunately any pro tools application below version 7.4.2 is not compatible with leopard and I don't think you can use mbox 1 with the universal mac I may be wrong but I wanna say I tried a while back and even garageband wouldn't find it anymore but you can check for sure by going to the applications folder then open the utilities folder in there is an application called "Audio Midi Setup" and you can select the mbox in there if you see it but if not there is no patch or driver that I know of to get it working unless you upgrade pro tools which if you do upgrade I suggest getting mbox 2 and getting LE with it
Mar 12, 2009 | Digidesign Mbox External Sound System
Using Keyboard for Mbox 1
You have to select the port in Pro Tools, but the computer has to recognise the MIDI port first.Does P.T. see that you have a MIDI port installed? Did you select an instrument plug in and map the keyboard as the controller for the plug in? You may need to use a utility like MIDI Yoke or MIDIOX to map the port if you are using Windows. You also have to have the drivers installed so that Windows recognises it as a MIDI port. If it is on a Mac you may have to use the Audio/Midi setup up utility to add the midi port.
Best of luck, Let me know if I can help further.
Dec 25, 2008 | Digidesign Mbox External Sound System
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
I cant hear windows
Your Windows System Sounds and sounds from other programs are output from the computers preinstalled soundcard. When you use a professional sound card i.e Mbox (ASIO) you can search google for an ASIO player or plugins for Real Player (or WinAmp or Windows Media Player etc) that allow you to use as the output device.
Jul 08, 2008 | Digidesign Mbox 2 Barebone
All the lights are on on my Mbox. it wont be recognized by pro tools. help!!
un plug it uninstall the mbox and all the asio drivers. update protools. then reinstall the mbox and all the asio drivers you should be fine.
Feb 12, 2008 | Digidesign Mbox 2 Barebone
PROBLEM KEEPIN MBOX 2 CONNECTION TO MAC LAPTOP
I have the same problem. Usually it will work when I reboot the computer. The trick is once you get the mbox working with the phantom power on, is to not turn off the phantom power during your session; the duration in which you use the mbox at that given time before shutting it down. You can switch the phantom off and it won't shut off, but if you press it back on, it may and for me more than half of the time it does shut off. I have a new problem with my mbox. I can't hear play back, even though I can hear sound from either input. Any suggestions?
Oct 26, 2007 | Digidesign Mbox 2 Barebone
Digidesign Mbox 2 Pro FireWire Audio/MIDI Interface Sound Card Logo
266 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
David Payne
David Payne
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
