Question about RCA RT2390 System
Optical cable is pluged in but the unit wont recognize it.
To get a digital or coaxial input, you must have the remote. Select the appropriate source on your remote (since you probably only have one digital input); it doesn't really matter which input you use. Hit menu, then use the left and right arrow buttons to select what you want to adjust, use up and down to adjust it to Coax or Digital, whichever connection you're using, then enjoy!
Posted on Feb 20, 2010
    Problem Solver:
  • 8 Answers
The problem is that you need to select the source on the remote of the unit and then select setup, you will be able to change the source from analog to digital (i don't remember the setting) and voila! it should work
Posted on Aug 22, 2009
My asus varidrive wont take in cds
does the drive accept the disk then spit it out or does it never close the door?
Dec 26, 2013 | ASUS SDRW-08D2S-U/BLK/G 8X Slim External...
Took my q7 to a garage to have a drop down DVD fitted, now my radio channels keep dropping out its like the aerial is only half working and the signal is really weak. I have checked the obvious things like...
Are you sure they plugged the antenna back in to the radio head unit? You need to remove the radio, check the back, there is a thick black cable (not fiber optic) that plugs into the back. Be sure it's in securely.
Oct 06, 2013 | 2007 Audi Q7 4.2 FSI
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
I have two devices that I want to hook up to coax audio and two more that I want to hook up to optical. When I have the unit set on the auto setting it won't recognize the coax or optical #2 inputs onlyt...
Swap one end of the cables for the devices between #1 and 2 to see if it's the device or the cables. Proceed to isolate the problem further from the results.
Optical cables are finicky and must be clicked in while also making sure there are no small-radius bends anywhere in the cables.
Jan 20, 2010 | Denon AVR-4802 Receiver
Computer wont recognize my mic
Check the cable pluged in your computer or if you have the driver for the mic install it .........
Nov 16, 2009 | Samson C01U Consumer Microphone
No sound from ps3 to home cinema via an optical cable
If you have not run the set up you will need to, however I'm guessing you did because you would have had to make some changes to the settings to get the image to come up on the screen but without being physically at your location I can just guess.
In order to view your PS3 in full 1080p you need the HDMI cable which you already have. If you have not gone into your video settings then you are not viewing via the HDMI cable and you will need to to get things working right.
In order to view via the HDMI cable you would have had to had both the standard PS3 interface cable that comes in the box (the one that goes from the PS3 to your tv with the composite video (yellow) and the left and right audio (red and white) and the HDMI cable pluged into your PS3 and your tv at the same time. then you turn on the PS3 making sure your TV was set to whatever imput the composite and left/right audio is pluged into (typically VIDEO 1,2,3 ect.) and enter the menu, go to the settings and then down to your display settings and change it to HDMI, the image should then leave the screen (because it switched to HDMI) you will need to have your TV remote handy for this because you will need to switch sources on your tv to HDMI 1,2,3 ect, which ever one you have it pluged into. When you have switched to the right HDMI imput there should be an on the screen that is counting down and asking you if you want to accept the changes. Select yes and Move on through the settings selecting the maximum resolution your tv is capeable of
720, 1080i, 1080p) which can be found on the box the tv came in or somewhere on the tv or manual. While running this settings change it should ask you the audio source you are using make sure you select Digital Optical and that it is pluged in to you PS3 and your reciever. Once this is all done you can remeove the standard PS3 hook up that came with the box and put it away you wont need it any more, unless you move the PS3 around and the tv you move it to does not have HDMI in which case you will have to change the settings before you move it back to the standard cable or you will not be able to see it displayed on the tv sceen you move to and it will be impossible to run the settings.
If you have already done that and just want to verify that your source for audio originating from the PS3 is digital optical you can check that in the same settings menu under audio settings. Then make sure the reciver is on and set to whatever imput you have the cable pluged into and you should be good to go.
If all that I have described has been done already then the audio cable could be bad or the problem lies internaly with the PS3 or the reciever.
Good Luck hope this helps
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Optical Port 2
i have the same problem - the only thing i have found so far is that I have to go into the setup on the amp and change the input for dvd from optical 1 to optical 2 and back again to switch between 2 devices
Aug 27, 2007 | Denon AVR-1800
RCA RT2390 System Logo
478 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
