Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
Transfer phone book to computer
How do i transfer all my phone number from my phone to my computer using a usb cable?
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
LG TU500 Bluetooth connection to Navman S80
That probably happens because the phone book is opened on the phone .
Use a computer to transfer the phone book from the phone to the navman using bluetooth or usb cable.
Oct 12, 2008 | LG CU500 Cellular Phone
Transfer pictures from phone to computer. I have the correct USB cable
I found an easy step by step to do this.
  1. Connect the USB cable to the computer and the phone.
  2. In the phone: When you attach the USB cable to the phone, a USB connection window appears, Select File transfer.
  3. On the computer: Open My Computer and your phone will be visible as a removable disk.
  4. Double-click the removable disk.
  5. Here you will find specific folders (depending on your phone model) where your pictures are stored.
  6. Drag and drop or copy and paste the picture from this folder to a folder on your computer.
  7. Disconnect the phone from the USB cable.
The picture is now transferred to your computer.
Hope this helps
Dec 22, 2010 | Sony Ericsson w580i Cellular Phone
My Samsung Impression came with a digital usb cable. What is that for? Can I transfer my contacts through the cable to my computer? Thanks!
the digital usb cable is always used for quick transfer of data between phone and computer... for some phones charging can also be done using usb cable...
Nov 07, 2010 | Samsung SGH-A877 Impression Cell Phone
How to get pictures from computer to phone LG gt505
there are few steps to transfer picture from computer to your lg gt505 phone.. its either you use bluetooth (if your laptop or computer has a blutooth), or you transfer it using a cable usb. cable usb is given to you when you buy your phone. every phone has usb cable. or u can transfer it using a card reader and put it on your memory card. hope this helps.
Oct 10, 2010 | LG GT505 Cell Phone
Use my music from computer to phone
Do you want to transfer music from your computer to your mobile phone?
Connect the phone to the computer using the USB cable that came with your phone. Or transfer the file using bluetooth
Sep 17, 2009 | Dell Inspiron 1200 Notebook
PHONE BOOK RECOVERY
If it is a CDMA phone, take it to the service provider and ask them to transfer it to their computer and put it on your USB flash drive or your new phone. If you are using a SIM card (GSM phone) you can transfer the numbers to the SIM card using the phone menu and place the SIM card in the other phone. With a SIM card reader, you can download the information to your computer.
Jul 05, 2009 | Nokia 6600
Trying to transfer phone numbers saved to only the phone w/o going to the store
you can use motorola phone tools (MPT) it has the transfer phone number option where you plug in one phone and it copies to computer then plug in 2nd and it copies to that. It's the easiest way. You could also use pst to backup your phone book, then just restore it to the new phone. modmymoto or hacktherazr.com would both have info on this.
May 04, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Transfer contacts
when u transfer the adress book contacts to ur sim and when u load the sim onto ur iphone..ur address book can be loaded or copied from ur sim to ur iphone..u cud also connect ur iphone to the computer with a usb cable and download the contacts that u had saved on the computer to your mobile using the software provied with the phone kit. all the best
Happy to help
Have a nice day!
tc
Jun 06, 2008 | Motorola Mobility RAZR V3
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
