Question about Whirlpool WED5500S Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
Whirlpool WED5530SQ0, dryer heats when knob turned but when push start pressed drum does not run. I checked vent and belt looks fine. Any suggestions. Gladly appreciated.
  • killgrnlf Oct 08, 2012
    I have same problem with same model and yes drum does not spin. Heat comes out still if u turn the left dial to a setting. I have a belt in center of drum (has grooves on under side) that is intact. I was thinking the push button switch to actuate the drum to turn (power) may be broken. Thanks and how many belts should u see?
    Scholar:
  • 84 Answers
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Posted on Jul 30, 2009
  • jonesky368
    jonesky368 Apr 04, 2012
    I have the same problem with the same model. When I turn on the dryer, it is heating up, but the drum will not turn. The belt is in tact, so I don't know what else could be wrong. The heater coil is hot as Hades, though. Please offer any suggestions you may have.
On my Whirlpool model WED5300SQ0 The solution to my units heating but not running was at the nonresettable thermal fuse. I disconnected the two wires to it and wired them together and pushed the start button and dyer ran. Replaced thermal fuse and unit works fine. The function of this fuse is to protect motor from damage.
Posted on Oct 07, 2012
    thanks for that post.....I will give that a try before I hit a store (94 miles away)
  • Rebecca Wade
    Rebecca Wade Jul 01, 2014
    where is the fuse on the whirlpool cabrio steam dryet
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool Gold senseon Model number GeX9868Jq1 I can feel the heat inside to Dromm but when I push start it just clicks It's a electric dryer
Unfortunately, it sounds like the motor, since you aren't hearing it run. Motor turns the drum by way of a belt.If motor is running, but drum not turning, it would be the belt... I would also say door switch, but then the heating element wouldnt be heating up. Slight chance it could be the control, but I doubt it. DW
May 12, 2014 | Dryers
My dryer-gas whirlpool the drum dors not tumble, the heat goes on
try and have the door open hold the door switch and have soem one push or turn the knob on at the same time spin the dryer drum clockwise by hand if it starts. you may need to clean the inside o fhte machine and the motor from any lint build up.or if the drum turns freely and easy you may have a broken belt or it might have slipt of the motor pulley.
Nov 03, 2010 | Dryers
Whirlpool WED5300STO When pressing start button, only dryer heat element turns on drum does not turn, can not turn off, must unplug to turn off, can plug back in, element is off but when pressing start...
If you have airflow through the machine, then the motor is running. You have probably lost the drum drive belt. To replace it, you must remove the top and front panels, plus remove a rear access panel on the lower back to reload the belt on the motor and idler. Hope this helps!
Oct 16, 2010 | Whirlpool WED5320SQ Electric Dryer
Whirlpool Super Capacity Dryer Front Loader 7kg : Drum does not want to tumble after push-button start. I opened the door and held the door switch in position as if door was closed. Then turn the drum into...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Whirlpool Dryers
Our dryer stopped working last week. We were drying a load and when we returned the dryer was very hot on the outside (more than normal) and the button to turn it on no longer worked. There is power to...
There is a in line thermal fuse that is in the machine near the heating element that has probably burned out from overheating replace the thermal fuse and check your vent pipe for clogs and or kinks that cause the machine to overheat.
Mar 08, 2010 | Whirlpool WED5500S Electric Dryer
Pushed dial, dryer would not start. Heating coil on, can feel the heat and hear ticking.
If the heating elemnts are coming on but the drum is not spining then the motor could be bad or the belt could be broken that turns the drum. The motor could also be on a thermal overload in this case unplug the dryer or turn off the circuit breaker for 15 minutes and let everything cool down. After turn the breaker back on or plug it back in and give it a try if you hear the motor running but the drum is not spinning then the belt is probably broken and will have to be replaced.
Jan 12, 2010 | Whirlpool LER4634J Electric Dryer
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Whirlpool 110 electric dryer will not keep running
When you press the start button you complete a circuit bringing the juice into your dryer to run the motor the igniter or heating elements and what ever else goes whee when your dryer is drying. So if you press the button to complete the circuit then when you let go of the button it would stand to reason that it break that flow and shut it all down. However in a dryer there is something of a centrifugal switch that kicks in and keeps that circuit open and flowing with juice once the drum begins to turn and you let go of the button. That's why in a normal situation if you don't hold the button down long enough the dryer will cut right back off or if you open the door to the dryer to throw something in and close it before it quits turning it will stay running. Sounds like you could add this centrifugal switch to the list of possible culprits in this mystery. O7OUT
Jun 06, 2009 | Whirlpool LER4634J Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Whirlpool WED5500S Electric Dryer Logo
846 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
