Question about Refrigerators
The plastic freezer liner is melting or disolving or decaying or SOMETHING all around the evaporator (coils) in my Maytag side by side. There has been no evidence by sight or smell of anything melting, but the liner is just disappearing to the point I can see yellow insulation and even some wires! The defrost feature is not working right at this point, so might that have something to do with it? I'm concerned as to how safe this unit is to run anymore. Anyone know what's going on with it?
  • coaterengine Jul 30, 2009
    Yes, that certainly helps. I'm handy enough to fix it, but could you point me to a good parts supplier and possibly a manual or schematic for the unit (MSD2656DEQ)? Thanks much.
    Scholar:
  • 117 Answers
Yes your defrost thermostat is not doing its job of limiting the heat buildup inside the freezer. Definately not safe to let it run like this.That being said, the defrost thermostat is easy to replace.Just two wires to cut, two wirenuts and it should work fine assuming the defrost timer is working .Also make sure the heater element is not out of it's mount and too close to the liner. Hope this helps
Posted on Jul 30, 2009
How do I defrost a HFZE54W
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Most refrigerators have a defrost timer and a defrost heater, therefore the term; "Frost Free". The defrost timer turns on the defrost heater every 8-10 hours, for about 10-20 minutes and defrost the freezer evaporator coil.
Of course you do not have this feature.
You will need a hair dryer, a plastic spatula and some old towels.
Take your time. Using the hair dryer melt the ice. As the ice starts to melt use the spatula to remove the ice in chunks.
Be very careful not to use a hammer or any metal tool. You may damage the freezer liner. If that happens, moisture will get into the freezer insulation, the moisture will freezer and expand and continue to crack the liner.
You have purchased a nice reliable unit.
Oct 18, 2014 | Hoover Freezers
My maytag MFI2569YEB ice cubes are melting around the coil in the tray. What could be wrong?
if you are talking about the bucket the cubes go into, most likely you do not use a lot of ice. the ice isn't melting, it's evaporating. usually winds up in a big clump at the bottom.
Oct 31, 2013 | Maytag Freezers
How can I access the defrost heater on maytag model rtd21a freezer/ref? I see only one screw in the freezer compartment. I have replaced defrost heaters in whirpool and kenmore. There are screws in those...
The defrost heater sits behind the evaporator coil. The evaporator coil lies horizontally between the freezer and refrigerator compartments. It is a lot of work to get access to the defrost heater. To do that you will need to remove the shelving in the freezer, both the refrigerator and the freezer doors and the trim pieces between the freezer and refrigerator compartments and remove the plastic liner at the bottom of the freezer. Once you removed the plastic liner, then you can see the evap coil and the heater is way in the back of the coil. Good luck.
Jul 01, 2010 | Refrigerators
Found water on floor and found that freezer is no longer freezing.
Hi
The problem could be a bad defrost timer, could be low on Freon. Pull the back of the freezer out, you'll have to remove all the food (yep, from the inside). This will expose your condenser coils. If it’s one big block of ice, then your defrost timer is bad. If the condensers are only lightly frosted on a portion of them and nothing on the rest of them, then your unit is low on Freon.
OR
You've got an iced up evaporator. If you look in the lower section of the freezer on the back wall, is the wall frosty or icy looking? The only way to defrost this is by taking the back wall out of the freezer and using a hair dryer on it (being careful not to melt the plastic liner) or to just empty the whole thing and let it sit with the doors open for a few days. Be prepared for water to leak out from under it however as the ice melts and overflows the drain tray in the bottom of the fridge.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jun 30, 2010 | Kenmore 57029 Side by Side Refrigerator
Water leaked from below refridgerator. Drip pan was not full. where woudl water come form and why? Unit is not eve 1 year old. mdel # KSCS 25 FVss
The evaporator coil is in the freezer. When it goes into defrost, that water should go down a drain in the freezer into the drain pan. Open the freezer door and see if there is any ice in the very bottom of the freezer compartment. If so, then the drain may be clogged and will have to be cleared. It is necessary to remove all of the racks and baskets to get to the sheet metal that covers the coil. Remove that panel to get to the evap coil and look below it to find the drain. It may be necessary to use a hair dryer to CAREFULLY melt any ice. Be careful not to melt the plastic liner. When you think you have the drain cleared, check it with a large glass of hot water.
If there is no ice in the bottom of the freezer, take the grill off the bottom of the fridge to see if there are any leaks under the fridge.
Could also be a pin hole leak in the water supply line to the fridge.
Mar 03, 2010 | KitchenAid KSCS25FVSS Stainless Steel Side...
The refrig. smell was on a JRSD209T sorry
Remove the food in the freezer , to a level , where you can remove the 2 screws holding the inside rear freezer panel , and remove the panel . At the bottom of the coils , is the defrost heater ( black rod piece ) . On the left AND right sides of the coils , down by the heater , check to see if the freezer liner is melted , due to the heat of the heater . This is a common problem for Maytag and Jen Air refrigerators , for the plastic to get hot . If this is so , then get 2 pieces of sheet metal , 4 " X 8 " , and slide in on both sides of the coils , to protect the liner permanently . If the liner sticks out , use a hair dryer to try and smooth out the plastic , to make it possible for the sheet metal to be slid into place .
On mine , I found 2 pieces of a lower dishwasher kick plate , and slid into place .
Nov 25, 2009 | Jenn-Air JCD2389G Side by Side...
I assume if my maytag msd2554dr has water coming out of freezer side I have a clogged drain. I have ice build up on bottom of inside freezer What causes the drain to get clogged in the first place?
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Warm refrigerator compartment lead to shocking freezer problem!
This sounds like the heater is shorted or the terminator is not good. I would probably replace both parts. As for the plastic I dont know if that needs replacing. You would have to look at that. There is 3 parts with the defrost system. The other part would be a defrost timer. You could replace that just to be sure. But I would definitly replace the heater and terminator.
Jul 29, 2009 | Refrigerators
Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Jul 22, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
