Question about Konami The Grinch for Windows
I can't quit the game. I tried pressing the Esc. button, but it didn't work. I even held the Esc. button, to no avail. Eventually, I had to just press Ctrl. + Esc., but that just minimized the game. If I can't access the Grinch's notebook with the Esc. button, I won't be able to save or load the game, let alone quit it. Please help me.
I had the same problem but realized the menu button was F1!
Posted on Dec 21, 2015
    Problem Solver:
  • 16 Answers
Use the hotkey Ctrl+Alt+Del to start task manager and then right click on the program you want to close. Then just click on end proccess. I think this is happening because your ram or processor is way too below the games requirements.
Posted on Jul 30, 2009
My usb overheated and now wont light up and let me see my files
This is WORKED FOR ME!--->I turned off my computer than unplugged cable and took out battery, held down power button for 1-2mins and than put everything back in (battery and charger) and tried to start it...the screen was still black. I than turned it off again, than pressed ESC, while holding down ESC I pressed and held power button until it briefly turned on and back off. Than I let go of both the buttons and pressed power back on and VOILA the screen came back on. Make sure your charger isn't loose, and than you're aren't surging too much power through the outlets-sometimes these can make the screen black too.
Hope this helps others out there, I have an old Toshiba Satellite running on Windows Vista
Jul 27, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
The taskbar disapeared
Press CTRL+ESC. If your Taskbar magically reappears, then it's probably simply been resized too small, repositioned somewhere you didn't expect it, or perhaps it's beneath another application that's running full-screen on your computer.
The workaround? Press CTRL+ESC to access the Taskbar.
If CTRL+ESC didn't make it come back, then the program that displays the task bar most likely isn't running.
That program is often called the "Windows Shell", but it's really "explorer.exe". It's the program that not only displays the Taskbar, but also responds to the CTRL+ESC sequence.
The workaround: press CTRL+ALT+DEL to fire up the Task Manager. Now on the File menu, select New Task (Run...). Type in "explorer" and press OK. That should restart explorer and re-display your Taskbar.
hope this helps
Jul 01, 2012 | HP Pavilion Computers & Internet
How do you fix speaker function button on hp d7
you have to replace keyboard. coz there is a problem with your keyboard.(hardware) .
thank you
Jan 07, 2012 | HP Pavilion dv7-1132nr Notebook PC
My controller won't sync.
remove the batteries and then try again. Press the Big X button on the controller, then the press the little white button on the Xbox next to the memory card slots. if that does not work, try also pressing the little white button located in the middle between the shoulder buttons.
May 04, 2010 | Microsoft Xbox 360 Wireless Controller
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
Proscan vcr model psvr71 is in lock mode following directions in manual won't unlock it, is there some way to get it out of the lock mode other than what the manual tells me to do ?
I read the user's manual again. I misunderstood and held both on/off button and vcr1 button at the same time. I should only have been holding one of the buttons for ten seconds or untill the vcr responded=-=-=-=-=-DUH !
Nov 02, 2009 | Thomson Televison & Video
My ar keeps telling me there isnt enough space left but i deleted all the games on it and i cant even put one game on it help
reset it
  1. With your console powered off insert the Action Replay DS
  2. Hold down buttons A+B
  3. Turn your console on
  4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
  5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
  6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
  7. take a while but will work
Jun 10, 2009 | Nintendo DS Lite Console
Ti-89 Titanium froze
Try pressing the "on" button.. simple i know but I tried cancel, quit, esc, off everything.. but pressing the on button worked..
Occa
Nov 09, 2008 | Texas Instruments TI-89 Calculator
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
Konami The Grinch for Windows Logo
179 people viewed this question
Top Konami Video Game Consoles & Games Experts
Dan Shibata
Dan Shibata
Are you a Konami Video Game Console and Game Expert? Answer questions, earn points and help others
