My tablet after a few seconds of inactivity automatically goes into sleep mode no matter settings or safe mode
    Sergeant:
  • Computers & ... Expert
  • 282 Answers
Tablet is a android or windows. there may be power saving option configured as lower than 1 min. go to settings menu. select display and sound , under display , select time out 2 min, and go to power option and use this help
http://www.microcenter.com/tech_center/article/6521/how_to_change_the_power_saver_settings_on_an_android_tablet
Posted on Dec 25, 2017
SOURCE:
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Posted on Mar 25, 2008
  • 300 Answers
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Posted on Sep 18, 2008
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
Posted on May 14, 2009
  • 37 Answers
SOURCE: Acer V223W monitor goes to sleep and doesn't awake
Go To Start > Programs > Accessories > System Tools > System Restore. Select "restore my computer to an earlier date". Look at the LIST of Restore points. Find the DATE when this "Security Update" was installed and Select the last date before it was installed and Follow the "Wizard" to Restore it to BEFORE the Update you think CHanged Things. Too many variables to figure out without seeing it to determine what was changed but that will correct the situation and you will not loose anything.
Posted on Aug 21, 2009
  • 51 Answers
SOURCE: The tv turns off automatically & standby light blinks 4 times
4 blinks is bad backlight inverter. Download the service manual here:
http://rapidshare.com/files/208591107/KDL40S2000_L5_sm.pdf
Posted on Aug 22, 2009
My lenovo s820 keeps on restarting
The first thing to do is boot it in safe mode and let it go to sleep, then wake it up and see if the problem goes away, If it does then the problem is related to something in the startup programs.
Feb 03, 2014 | Lenovo S820 Android 4.2 MTK6589 Quad-core...
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
LCD monitor turn to sleep mode
Does it turn off or go to sleep? If it turns off , there may be a setting that needs to be reset or reprogrammed. If it goes to sleep because of inactivity, just move mouse to awaken it
Sep 27, 2012 | Vocopro Ltv-5 LCD Display System
My monitor went dim and goes black after a few seconds. I can just turn off the monitor for a few seconds and then it comes back for a few more mintues but still is dim and goes black again. Also while...
I don't know what OS you have but there is a power management setting you might want to check. Most likely the monitor is set to go quickly into sleep mode at inactivity. Alternately I don't know what monitor you have but it might be a backlight Issue as well
Dec 20, 2017 | Acer X Computers & Internet
My computer stopped working in the regular settings, so i decided to do a factory settings restore, well it worked but now i cant get my computer out of safe mode, it automatically goes, no matter what i...
It only means that windows.ini was not successfully installed. You need to reinstall the operating system again or else your computer will be stuck on safe mode.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 21, 2011 | Dell Inspiron M5030 Laptop
My smart board randomly goes blank. Sometimes it happens after 10 minutes sometimes it will go a whole hour. We have ruled out the sleep mode. Audio continues to work. Any ideas?
It seems as the projector is overheating possibly, or is going into sleep mode from inactivity. Go through the projectors settings and see if you can find a sleep option and clean the filters for the projector.
Jan 20, 2011 | Smart Technologies SMART Board 580 (SB580)
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Open Questions:
Computers & Internet Logo
41 people viewed this question
Alun Cox
