Question about KitchenAid KUDK03ITBK Built-in Dishwasher
Not cleaning low pressure smells hot looks like
Not cleaning the dishes; low pressure; smells hot; looks like heating element has been too hot, sections of it have turned a burnt brown color, burnt smell when the door is opened during the wash cycle. Tub doesn't look like it has been enveloped with water when the door is open. The Electrasol powder ball tabs not disolving during the course of the cylce. Have tried several detergents and not satisfied with any of the results. Think it is probably not detergent fault. Inside of the door is often white from detergent residue
    Scholar:
  • 117 Answers
Sounds like the dishwasher is not getting enough water during it's fill cycle due to low water pressure on supply line or the dishwasher pump is not working correctly. Could be obstructed with food matter, etc.Hope this helps
Posted on Jul 30, 2009
Hi! I have noticed that my dishwasher is not cleaning the dishes like it used to. It is leaving a residue on all of my dishes and the glasses, usually, look horrible when they come out. It's driving me...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 07, 2011 | Frigidaire FDB1502RGC Built-in Dishwasher
Model 587.14134102 dishwasher is not cleaning well. Unpon checking it by opening it up during various cycles the water does not seem hot enough. The dishes are warm to the touch but not hot. How can I...
Does your machine take in hot or cold water. If it takes in hot water the element that heats and maintains the heat may be defective. If it takes in cold water the element is heating it but the thermostat is cutting out the element at too low a temperature. Normally dishwashers take in cold water and heat it to the required temperature, which would mean that the thermostat is faulty?
Feb 06, 2011 | Kenmore Dishwashers
Always smells after clean load empty. Water in the reservoir looks dirty. Now see some food deposits on one side of the door base inside machine.
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
A helpful rating and a testimonial would be greatly appreciated if you are satisfied with my solution...
Oct 05, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
My dishwasher is filling up with water but it is not cleaning dishes. the lower spray arm is moving but has limited pressure. The top sprayer is barely moving. Water gets hot but seems as thought the...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
agf23
Sep 06, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishes arent clean
We have had a terrible problem with dirty dishes after cycle since getting this dishwasher as a warranty replacement for a Maytag Jetclean (that worked WONDERFULLY but completely blanked out one day). I can't say I have a great answer for you, but our problem is apparently that there is not enough water for the cycle. This varies from time to time it seems like. We have good pressure in our home and good pressure going to the dishwasher, so the problem is possibly valves??? I don't know, we are waiting to see if this will fix the problem. We also have an element that glows and smells hot (could be due to low water also. These are the things I know--perhaps you could make sure you have good water pressure all the way up to the dishwasher to eliminate a water line problem.
Mar 19, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Dishwasher does not clean the dishes properly
Hi
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Bad smell on dried dishes after being washed.Stale water smell.
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors.
trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids.
run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
Jan 06, 2009 | Dishwashers
KitchenAid KUDK03ITBK Built-in Dishwasher Logo
210 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
