I have a Whirlpool Cabrio washing machine. It will not fill. It starts to fill and shuts of the water flow after about one minute or so and a code F 50 is displayed. When I put it on rinse/spin and start it will pump out but will not go into spin cycle. I was told to replace the RPS sensor. I replace it with a kit from the parts house which included a harness that was also replaced. Still getting the code F 50. The brain has been replaced once, the lid lock has been replaced twice, all under warranty. Now it is out of warranty, and I'm out 90.00 for a part that I was told by two experts would fix this machine. Please, I need right answers.
  • 1 more comment
  • t58scouter Jul 30, 2009
    When I replaced the RPS sensor today and the harness, the harness had a new hose attached to it as well. There are no kinks or pressure spots in the hose. I did check this arlready.
    Could the problem be in the control panel?
    If the valve solenoid was bad then it would not open at all. Also if one side was bad the other would still continue to work. The machine does put water into the tub but only for a short time. Then stops and the code comes up. Even if I put it on a soak cycle. It will start to fill but stops in a minute or so, and shows code F 50.
    When I put on spin cycle the timer shows 11 minutes and then jumps to 8 minutes, begins pump out and continues to pump out but never goes into the spin mode.
    Thank you for your help on this.
    President:
  • 1,776 Answers
I can't guarantee anything, but I want you to try something. If it works, it won't cost you any more money. I want you to check the routing of the pressure switch hose. It travels through a conduit with the wire harness and is very cramped. Sometimes the conduit has to be split slightly to free up the hose and alleviate kinks. Sometimes it is like the constant pressure seems to get to the hose, weakening it, and causing it to collapse and be crushed. This has been known to cause this type problem on this type washer. What the hey, it's worth a try, right? I sure hope this helps you and best wishes.
Posted on Jul 30, 2009
  • 1 more comment
  • Bruce Canfield
    Bruce Canfield Jul 30, 2009
    The problem could be in the circuit board, and I don't like to make you wait, but I will need a little time to think this over. While I ponder this, and since you said that it starts filling and then stops, I would like for you to check the solenoids at the water inlet valve. I am attaching a picture and I would like for you to use a multimeter to check the solenoids for continuity. If either one has no continuity, it is bad and the inlet valve will have to be replaced. I will think this over and get back as soon as I possibly can. Hang in there.
  • Bruce Canfield
    The problem is the machine control board.
  • Bruce Canfield
    I did some research and heard that Whirlpool had trouble with the machine control boards in some machines. The control boards were manufactured in China and were causing the F50 code as well as the F68 code (this indicated a pressure problem). The machines would cut the water off right after starting. Sorry about that.
Our cabrio washer (whirlpool) is not filling with enough water
You should have a LF code if so, then the water valve is your problem.
Jul 06, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Lf code comes on twice during clean cycle and I have to press start button to get it working again
Ok this error means Long fill as you know, Basically if the machine has not filled after 10 minutes then it goes into this error condition. First thing to do is make sure the taps are turned on, they likely are so unplug the machine, shut the taps off then unhook the water lines at the rear of the machine, next look inside the vlave (where the fill pipes hook up) and check the filter screens, these are likely clogged.
Jun 27, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer is getting OL code after about 10 mins.
see http://forum.appliancepartspros.com/washer-repair/192305-cabrio-washer-code-ol.html as more ideas on this type of problem suggested
Mar 27, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio washer model WTW6200SW, when the wash cycle is started, starts filling with water, after roughly one minute the machine stops than goes into spin cycle, will spin for a short time than...
Possible there are errors in the program memory. Power off the washer for half an hour, press and hold down the start button , then switch on. Try also with another program. Also check if the inlet filter is clogged and the water flow is good, if not clean. Also check the water level pressure sensor.
Nov 01, 2013 | Washing Machines
The wash cycle puts in too little water and ends up with an oL signal
there is an over fill switch in the washer,,there is a pipe leading up to it when water go.s into the tub the water presher fills the tube up and when the presher is right it turns off the flow,,, if it "times out" becouse it took to long to fill up it shuts off the water flow if this tube is blocked up with gunk??? it wont work very well,,,if its gone fulty it also stops the flow of water ,,,hope this help you out?
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Lf code on washer.checked hoses and valve both ok unit will run after opening the lid and closing lid and pressing start again. takes 10/15 minutes for a load to start
LF means that it is taking too long to fill. (If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.)
Supply hoses could be kinked or clogged(some have screens in the end).
This could be a supply water pressure/flow problem. Make sure you have good water flow though the hoses to the machine. (Take off and try running into a bucket)
The water fill valve may be failing to open all the way or it could be clogged.
I hope this helps.
Mar 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio
LF means long fill, so if your hoses arnt blocked and you are getting good flow, try looking at your drain pipe, it should only go about 6 inches into the actual drain and zip tie it there. any further it could syphon the water out of your machine.
Apr 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
