Im tryin to burn a movie with dvd flick when i click create dvd i get a warning "Its recommended to put your project destination folder on a drive with the ntfs file system. older systems like fat32 cannot handle files larger than 2 gigabytes in size which can be created during the encoding process if this happens encoding will fail" how do i do that
  • anthony allison May 11, 2010
    how big is your harddrive and what os are you running(operating system)ex::xp,vista,98
    Novelist:
  • 166 Answers
To fix this you just need a harddrive above ten gigabytes(each movie can take up ten gigabytes)and the harddrive needs to be ntfs.you can only put fat32 on a drive that is less than 30 gb.i would not recomend using fat32 its faster than ntfs but less secure.you can either get another harddrive with a ntfs files system or reimage the os and make it ntfs.fo that you need a xp installation disk
Posted on Jul 30, 2009
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Tip
How to Rip & Burn DVDs on a Mac
1) Download and install Handbrake. This free software allows you to easily rip DVDs on any Mac with OS 10.3.9 or higher. Download and install Roxio Toast to compress and burn the DVD,
2) Insert the DVD that you want to rip into the DVD drive. Close any DVD program that starts automatically. Open Handbrake.
3) Make sure that the "Detect Volume" option is selected and click the "Open" button. The Handbrake software will scan the DVD, collect all pertinent information and open the main menu.
4) Make sure that the title Handbrake selected for the DVD is correct. If it is not correct choose the appropriate one from the "Title" menu. Choose a destination for your ripped DVD in the "Destination" section of the menu, the default being your desktop.
5) Click the "Rip" button. (Do not interrupt the process or turn off your computer until the DVD is ripped.) This will create the ripped files and a folder structure which includes a "VIDEO_TS" folder.
6) Open Roxio Toast and select the "Video" tab. Select the "DVD-Video" option from the "VIDEO-TS" menu. Select the "Fit to DVD Compression" option to burn the ripped files onto a single-layer DVD.
7) Choose the "VIDEO_TS" folder that you just created by clicking on the "Select" button. Choose which options you want for your ripped DVD with the "Copy Options" button.
8) Insert a blank DVD into your DVD-R drive. Click the red "Burn" button in Roxio Toaster and allow the program to run its full course. Now your DVD is ready to watch on any DVD player.
Hope this helps.
on Sep 10, 2010 | Computers & Internet
In simple language, how do I burn a movie that I am playing on a NW8240
if you only have one cd/dvd drive you will have to copy the dvd into a folder first then burn it to a disk
click start all programs accessories windows explorer you will see your drives C: hard drive D:or E: your cd or dvd drive
to make a folder in windows explorer my documents right click select new folder you can name it then
right click on your dvd movie select copy then go to the newly made folder right click select paste
from there open up your burning program select make a dvd movie depending on which software you have this might differ
if you need more help with this post a reply
hope this helps
Nov 13, 2011 | HP Hewlett Packard HP Multibay nc6220...
Im a bit clueless but i have a downloaded movie on my pc and want to be able to put it on a disc, i have a compaq 6720s , does it have a burner inside it? what do i need to buy or install to be able to use...
I'm going to assume you are using a Windows operating system if you are using Windows media player. Windows media player does not come with the ability to burn or rip dvds. If your computer came with a dvd burner installed it should have also come with the burning software. You need to look for software labeled "Nero" or "Roxio" or another name that alludes to the fact that it will burn your dvds for you. Most of the software is pretty user friendly and if you need help using it you can just Google the software name and what your problem is and you can usually find an answer.
Now the tricky part is getting the video to a format that will allow you to burn it to dvd AND be played through a standard dvd player.
In order for your video file to be played in a standard DVD player it will need to be encoded in the MPEG-2 format. You will need software to do this for you. An excellent program would be "DVD Flick"
LifeHacker has put out an excellent tutorial explaining how to use DVD Flick here:
http://lifehacker.com/232322/hack-attack-burn-almost-any-video-file-to-a-playable-dvd
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 06, 2011 | Computers & Internet
Tip
How to remove iTunes DRM copy-protection and burn iTunes movie to DVD?
Many friends ask me how to burn iTunes movies to DVD, so that they can enjoy their movies on large screen TV. For computer newbie, I will recommend them to get an Apple TV; it can connect your iTunes library to TV, the only thing you need to do is to sync movies from iTunes to Apple TV box. An Apple TV costs $299, if you think this is beyond your budget, you can use software to do that same thing, which is a lot cheaper.
Now, let me explain the details. Because movies and TV shows purchased from iTunes store have DRM copy-protection, you have to remove the DRM protection before burning them to DVDs for playback on your home DVD player.
What you need are: Aimersoft DVD Creator & Tunebite. You can download them from:
http://www.topsreviews.com/dvd-creator/dvd-creator-aimersoft.html
http://www.dvd-video-converters.com/dvdvideosuite/backup-copy-protected-music-and-video-with-tunebite.html
Download Aimersoft DVD Creator
    Part1. How to remove DRM copy-protect from iTunes purchased movie or TV shows?
    Step1. Download and install Tunebite, just follow the installation wizard, this software will install several high-speed dubbings to speed up the conversion, when you see the pop up warning messages, just click “Keep on going” to finish the installation, which may take a few minutes.
    Step2. Then run Tunebite, click “Add” button to load your iTunes purchased movies or TV shows, the default directory is My Document\My Music\iTunes\iTunes Music
    In the “Convert Video to” drop down list, select “WMV7 (1024 kbps)”, then click “Start” to begin the conversion. If you don’t know where the converted videos are saved, you can click “Folder” to locate the files on your computer.
Tips: this software can also remove DRM from purchased music and audio books; it also works for other online stores such as Zune, Amazon, etc.
Part2. How to burn DRM-free iTunes video to DVD?
Step1. After you remove the DRM copy-protection from iTunes purchased movies, download Aimersoft DVD Creator and install it. (Note, you need a DVD Burner to burn DVD, so make sure your DVD Drive has DVD+RW or DVD-RW symbol)
Step2. Run Aimersoft DVD Creator, click “Load Video” button to import your DRM-free videos, and then drag the videos to the storyboard. If you want to burn videos to dual-layer DVD (DVD-9), at the bottom of the interface, select “DVD-R 9.0G”, you can also customize video quality there. And the used disc space is shown on the disc space bar underneath the storyboard.
Step3. If you just want to burn the video to DVD without adding any special effects, just click the “Burn” tab. Here you will see the following options:
“Burn to”: you can burn the video to DVD or create an ISO file on your hard drive.
“Drive”: If your computer has multiple DVD burners, you can select any of them.
“TV Standard”: NTSC is 30 fps. It’s used in USA, Canada and Japan. PAL is 25 fps and it’s used in Europe and Asia.
After the above steps, put a blank DVD disk into your drive and click “Start” to burn your movie.
Tip. You can use this software to add special effects to your videos and also create a DVD menu so you can use DVD remote control to control the playback.
Besides this you can also ues other softwares to help you to solve some related problems. I
have being used software called dvd burning
software
, which is easy to download and install, most of all ,its price is considerably
reasonable, if you are interested in it you can have a try. Best wishes for you! Of course you can have more choices for you, you can have a close look at best video editor to get more useful and
practical information for you!
on Jul 26, 2010 | Computers & Internet
Tip
HOW TO COPY A DVD WHICH WILL PLAY ON A X BOX TOOLS YOU WILL NEED: DVD decrypter...
DVD decrypter
DAEMON TOOLS
DVD2ONE
NERO 5.5.10 or above.
1. Rip the DVD in ISO mode with DVD decrypter to your hdd.
(mode=ISO-read)
2. Right click DEAMON TOOLS icon on your desktop
virtual cd/dvd rom
Device 0 [k] no media
Mount Image - ISO file
3. Make a main folder ( title MOVIE ) on your desktop.
make 2 subfolders in it VIDEO_TS and AUDIO_TS
4. Open DVD2ONE. choose movie only or entire disc.
source - drive you mounted in step 2 (VIDEO_TS)
Destination - VIDEO_TS folder you created in step 3.
start
5. DEAMON TOOLS - unmount the drive you made in step 2.
you can now delete the ISO file to save disc space
6. open NERO
close wizard
New Compilation DVD
Left Column (DVDROM/UDF/ISO)
No Multisession
UHF check Force DVD compatability (required for x box)
Label ( NAME OF MOVIE ) ALL CAPITAL LETTERS
Click New
drag over the VIDEO_TS FOLDER and AUDIO_TS folder you made
BURN
on Jun 04, 2010 | Computers & Internet
Burning of DVD from Power Director V7
LOOK IN TOOLS AND SETTINGS OR HELP AND FIND THE UPDATE BUTTON AND UPDATE THE SOFTWARE. PLUS YOU ARE RIGHT THAT IT MAY BE PROBLEM USING EXTERNAL DRIVE.(IS IT USB 1.0?)..COPY YOUR FILE TO A TEMPORARY FOLDER ON YOUR DESKTOP AND BROWSE TO THAT FOLDER WITH POWER DIRECTOR.
May 28, 2009 | CyberLink POWERDIRECTOR 7 VLICDELUXE for...
Tip
Play Blu-ray movie with HDTV DVD Combo ? Burning Blu-ray to DVD
HDTV DVD Combo features a built-in slot-loading DVD player, which provides an optimum way to save space. With the slim profile, it’s really an amazing experience to watch favorites TV shows and DVD movies on this device in your bedroom. But if your TV only has a standard DVD player but not the Blu-ray disc player, what is your solution to play Blu-ray movies on it? I'd like to know your ideas. I believe my way is somewhat helpful, just convert BD to a DVD format, and then burn it to a blank DVD for playback on the TV/DVD Combo, so share it here, and also be glad to hearing from you guys.
The software I used is as below:
- (http://www.pavtube.com/blu-ray-ripper/ ) Pavtube Blu-Ray Ripper
- (http://www.videohelp.com/tools/ReJig) ReJig (freeware)
- (http://fileforum.betanews.com/detail/ImgBurn/1128426215/) ImgBurn(freeware)
HOW-TO:
Part 1:
Firstly, use Pavtube Blu-Ray Ripper to remove copy protections of Blu-ray movies, and meanwhile convert it to the DVD vob format.
1. Run Pavtube Blu-Ray Ripper and click "DVD Rom", "DVD Folder" or "IFO/ISO" to load Blu-ray movies. Generally speaking, the file with the longest duration time would be the main movie, if you just need back up the main movie, tick off this one only.
Each file will be checked by default after imported, right click on any one of the files, and then there will be a popup window to let you uncheck all, just do it, and afterwards to tick off the checkbox before the file you need converted.
2. Click on the drop-down menus after "Subtitle" and "Audio" respectively to select your required languages and sound effect.
3. Select VOB as output format and specify destination folder
Click on the pull down list of "Format" to select VOB as output format and click on the folder icon at the opposite side of "Output" to specify destination folder.
4. Customize output settings
The popup window will allow you to adjust audio and video parameters including codec, bit rate, aspect ratio, frame rate, sample rate, and audio channels to optimize the output file quality.
5. Click on "Convert" button to start BD ripping
Once finished, you can find out the output files via clicking on "Open" button with ease.
Part 2:
Then use ReJig to do DVD authoring.
It's pretty simple with ReJig. Press "File Mode"; add your vob files and Demux.
When it's finished, close that box and then select DVD Author. Add the video and audio files you've just created, and choose output destination folder, and click Create.
After DVD authoring is completed, you can open the destination folder to see that the output files are AUDIO-TS and VIDEO-TS folders, which are the correct structure for DVD burning.
Part 3:
Use ImgBurn to burn DVD
We have got VIDEO-TS folder in part two, so the DVD burning process with ImgBurn is pretty simple. Here give you two links to check the detailed steps:
(http://forum.imgburn.com/index.php?showtopic=4632 ) How to write DVD Video files directly to single layer media using ImgBurn (DVD±R/RW)
(http://forum.imgburn.com/index.php?showtopic=4643) How to write a DVD Video double layer disc using ImgBurn (Verbatim DVD+R DL) – just check the contents that start from adding VIDEO-TS folder of this guide.
The end! Hope this helps.
on Mar 10, 2010 | Televison & Video
Tip
on Feb 05, 2010 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
