Question about Refrigerators
How do I stop mildew from recurring in my SubZero 532 side-by-side refrigerator/freezer?
  • 560 Answers
First, make sure the door seals are in good shape and the unit seals. Then, use a 20% bleach / water solution to sanitize all inner surfaces and seals.
Posted on Jul 30, 2009
SubZero 532 model Water collecting in bottom of refrigerator below vegetable drawers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Refrigerators
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
I have a subzero model 532. I turned off my
its quite possible that your fill tube is clogged with a bit a ice
Oct 09, 2009 | Refrigerators
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero 532 refridge cooling but freezer won't freeze
Unit has separate compressors and thermostat's. Clean the condenser, if it doesn't improve call for service, as there is a decent chance you will need sealed system work or defrost issue. If you need instructions on cleaning the condenser check subzero.com.also try advanceing the defrost timer as they mostly die in the defrost cycle. Behind the grille there will be a panel with a small hole in it with a screw above and below. Use a flat blde screw driver to turn the gray piece in th small hole clockwise a few clicks. If the freezer comes back on you will need to replace the defrost timer.
Jul 26, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero 532 fridge is warm/ice on inside back
the stop leak works if its a very small leak only. partial charge is just topping off the freon. would give the stop leak a shot first. about $70 bucks a can.
Jun 08, 2009 | Refrigerators
SubZero Model 532 (1994) Refigerator/Freezer:
My SubZero 550 Regrigerator/freezer is not making icecubes. Any ideas
May 12, 2009 | Refrigerators
SubZero 532 frig lights out
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to www.subzero.com there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
Nov 30, 2008 | Sub-Zero 561 / F
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
