Error code SC998 on Ricoh Aficio 1045
On starting the machine I am getting an error code SC998 on Ricoh Aficio 1045 and the machine software will not load.
  • 313 Answers
The error code 998 is usually for the dimm or application boards read errors try taking the memory out and the app board out and reseat them again.. then go into the service mode via yellow clear button and then enter 107 then hold down the stop button till the panel changes and turn off the copier wait for 5 secs then turn back on.. If you dont know where boards are take the back panel off and on the right hand side there is a box with a steel plate on the dimms Ram..and app boards are there.. Good Luck A..
Posted on Jul 30, 2009
  • 162 Answers
Reset the software:
press . y # at same time for more of 10 sec. Until the copier is off Automatically it will return to ignite and it will print a page with a code of error more approximated to which display.
It would be necessary to see as it shows.
I would try with changing the hard disk.
Posted on Aug 31, 2009
How do i fix the error code sc998?
998 Application start error • Software defective; change the firmware for the application that failed • An option required by the application (RAM, DIMM, board) is not installed
Oct 08, 2015 | Ricoh Office Equipment & Supplies
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
I turn on my ricoh aficio copier 2022 this code sc998 appear
The meaning of the error sc998 is the system software does not start within 60 sec.The cause for that is either the RAM, DIMM (software SD cards), firmware(system software) or the main controller is faulty or not connected properly.
Did you remove chip or SD card from the machine?
Mar 11, 2010 | Ricoh Aficio 2022 Black and White Copier
RICOH AFICIO AP3800C CS 99 CODE HOW CAN I FIX THAT
I am new to this printer myself. but most codes error I see have 3 numbers to it I can only say that the codes I see for this printer with 9 in it are:
SC990 Defective software
SC998 Application start error
Maybe the machine lcd not show all the number on it.
Pineworks.
Jan 05, 2010 | Ricoh Aficio AP3800C Laser Printer
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Dec 28, 2009 | Ricoh Aficio 1035 Copier
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
Hello, got an old Aficio 1045 with headcrash. I
The 900 code is the software error code.Enter in theuser and SP modes and configuration the new duplex.For more information please answer.
Sep 28, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
May 26, 2009 | Ricoh Aficio 1035 Copier
SC998 problem
(RAM, DIMM, board)
ends abnormally.
998
D
• Download controller firmware
• Replace the controller board
After power on, the application does not start within 60 s. (All applications neither start nor end normally.)
your firmware got messed up propably so you will need to obtain the controller board firmware , or when you print something you select a function on the pc that is not installed on the machine hope this helps you
Oct 31, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
1,281 people viewed this question
jasbo
jasbo
